Question about Kyocera FS-3900DN Laser Printer
7410:0160661 What does this code mean its on a fs-3900dn I have looked all over the web with no luck thanks in advance
    Problem Solver:
  • 14 Answers
Did the error came on after replacing tonercartridge ?
open the door at the left and push on the drum till you hear click, problem should be solved afterwards.
Posted on Sep 16, 2008
Kycoera FS-3900DN service code 7410-0013781
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Kyocera FS-3900DN Laser Printer
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
Hi, I have a problem with my Kyocera FS-3900DN. The display shows the fault 7410:0043899. How can I fix it? Thanks
Will just reflashing the firmware fix this?
I have replaced the EEPROM (as per my post near the top) on a few of these, so that the printer will come to ready and then flashed the EEPROM via parallel port with upto firmware.
skyp techbelkin
Dec 19, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
How do get the meter reading on this?
The best way to give an answer to this question is to go to:
http://www.retrevo.com/support/Kyocera-FS-3900DN-Printers-manual/id/529dj780/t/2/
Download the ADVANCED.PDF manual and go through the steps from page 2-1 to 2-14
Nov 30, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900dn showing 7410:0024216 error code what do I do
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Apr 15, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Service code
This is a laser problem. The polygon motor probably got jammed usually it needs to be cleaned and oiled or the motor has ceased.
Mar 10, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
134 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
