Question about Sony Playstation 3 (PS3) Console
Video Glitch / Lock up
Allright, this problem is a persistent little thing and it isn't only prone to the beginning.
Problem::
The problem is that the system locks up, the display on the screen goes multi colored and everything simply stops. Once reached this phase, you may eject the CD, put it back in, unplug the video cable form either TV or console, plug it back in, unplug controler and put it back in... and nothing happens.
Next::
Turn off the console, turn it back on, start it via the button in the front.
Let's say that it loads and the default menu appears (has only happened twice, and I've turned it on and off several times) you can flip through the menus, all fine and dandy.
The minute you put in a game the above has a chance to occur, now and again it will not but eventually it will happen while you're playing the game.
So. No matter what you do the problem will come up, I am curious on how to go about fixing this doozey.
At first I thought that perhaps the system was over heating and thus the colors were going all woozy, but I'm uncertain and have been unable to figure out anything from the internet.
  • smbshb Jul 25, 2008
    My Playstation 3 locks up at start up. Can not even get to the menue. Do not know what to do or how to fix.
Sounds like your gpu is bad. hafta send it to sony to fix since they are only ones so far that know how.
Posted on Jul 25, 2008
Why are all my videos on facebook green, there is audio but on video
You can upgrade for free to windows 8.1, that may fix this problem. Follow this guide to upgrade.
Update to Windows 8 1 from Windows 8 Windows Help
If problem persists, it may be an issue with your browser or adobe flash. Try updating both.
Jan 29, 2015 | Google Computers & Internet
Power locks will not unlock with the remote, remote is allright
Try replacing the remote battery and retrying as this is often the issue with remote central locking. The LED may light, but if signal strength isn't strong enough, then nothing is going to happen.
Do the locks lock with the remote?
Oct 31, 2012 | Cars & Trucks
My segs sometimes goes in slow motion while im playing a game then.
Mine does the same thing maybe the gamepacks need to be cleaned out then or its a little glitch too.
Qutips and rubbing alcohal.
Jun 12, 2011 | Sega Genesis 2 Console
I can get games to load but they glitch out when im playing
You know that system is such old technology those machines were bad for problems like that. There is nothing you can do, they don't make anything to help the problem anymore ..
Sorry
Jul 21, 2010 | Nintendo NES Console
The abs light is constsntly on what does this mean?
It means there is a problem with the Anti-Lock Brake System (ABS). Can be any number of things.
Jun 07, 2010 | 2001 Daewoo Nubira
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
My computer experience errors, suddenly hangs up, freezes whenever i do video calls..
This may not be with the computer, it could be with your internet provider. If you have a bad or unstable internet connection, then a minor glitch or quick loss of connectivity will cause you to lose the call, even if the glitch is almost unnoticeable. If connected wirelessly, then try a cable and hardwire directly to the net, a wireless glitch could do the same.
Aug 02, 2008 | Dell XPS M1330 Notebook
Toshiba P-30 Screen Problem
Well Jim, this could be a couple of things, a simple driver glitch, or a dead pixel area. Let's hope for the driver glitch. Start by uninstalling the video drivers from the device manager, then reboot. The machine will find the screen and reinstall the video drivers. Then readjust the screen resolution in the display properties. If the problem persists, then I'm afraid you have a dead pixel area. This will be caused due to a bad screen inverter or bad screen, then the inverter or screen will have to be replaced. It's very rare, but occasionally a loose or bad connector can cause this. You might also check the screen connections for a loose connection or a little dirt/corrrosion build up.
Jul 20, 2008 | Toshiba Satellite P30 P35 Series Notebook
Repaired!
congratulations, it may help you if you use a bit of water with a bit of detergent as lubricant when snapping back the rubber gasket in place.
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
Sony Playstation 3 (PS3) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
