Question about Panasonic PT-AE900U Multimedia Projector
No image, lamp light blincking red
I turn on my projector but don't get any image at all. Not even the blue Panasonic screen. Nothing lights up inside the lense either. The lamp light on top of projector starts to blink red after a couple minutes. Lamp run-time is approximatelly 400 hours. It has been raining real hard with severe thunderstorms. Couple lightning bolts seen to have hit VERY close to our house. Could a lightning bolt have burned out the lamp or could it be another technical problem?
  • Anonymous Aug 06, 2008
    I just experienced the same problem with my PT-AE900u last night. I turn on my projector but don't get any image at all. Nothing lights up inside the lense either. The lamp light on top of projector starts to blink red after a couple minutes. This was a cold start, that is I had not used it for several days. My lamp run-time is approximatelly 800 hours. After several attempts It finally came on. Is this a sign that I need a new bulb? I read the manual, and it said the bulb should be good up to 3000 hours of use. What gives?
  • arikdafni Oct 07, 2008
    Hi
    i have also the same problem my lamp time is around the 1800h but now it doesn't turn on, when i switch it on it sound like there is a problem with the fan - it make noses like its going to start but it doesn't. also b 4 it died on me i notices the lamp indicator and the temp ind were blinking and the pic was slightly instable. i tried to clean it with some dust got out but it didnt help the actual problem
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Posted on Jul 05, 2009
  • harold279 Mar 10, 2011
    My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise.\r\nI never got any warning on the screen saying the bulb was in need of replacing..but its close to 5 years old. Do i need a bulb..or did the thing burn up?
    please help..
    Problem Solver:
  • 11 Answers
Sounds like ballast unit. avalontc.com
Posted on Aug 06, 2008
I have a panasonic pt-ae 900u projector and it is used in a room where we have a wood stove and i am sure it is dirty inside. It got hot and went off several times. It will run for a few minutes now and then goes off. I think the time on the bulb has expired but think maybe it could be dirty. Is there a way to clean it myself or do i need to hire someone? Also, where do i get a bulb that isn't 300 dollars. I can't afford that. Thank you so much. nellie
Posted on Jul 30, 2008
Image/power issues
A lot of projector lamps / bulbs only have 2000hrs of expected life. that's about a year if you use it to watch TV. Do you have a backup to try out ?
Oct 25, 2013 | Canon XEED SX50 Multimedia Projector
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
Failure to get a trully blank or black screen
Have never worked on a panasonic projector before I admit, but you get that effect when the 3 LCD panels inside a Sharp (and I assume all brands) LCD are misalligned. To get total black (LCD Projectors find this rather difficult due to the technology) the red , blue and green lcd pixels must be precisely allignend ( they are adjustable by technician and it's a fiddly job) I reckon the green panel is a touch out and it's peeking out between the red and blue squares.
Dec 12, 2009 | Panasonic ET LA780 Projector Lamp for 780...
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
Panasonic PT-AE900U Multimedia Projector Logo
835 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
