I replaced the ignitor and it's sparking but the spark isn't going to the burners to start the flame, having a hard time finding any info on Jenn Air. Thanks, Jimmy
-   I have a Jenn Air grill and the ignitor doesn't work so I have to use a match to light it. I want to fix it but have no idea what the problem is. Please help. Thanks-   abash8
Jul 31, 2008
-   No spark to any of the burners. Change the battery still no spark.-   dgoode5450
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
i have a propane, ventless type stove. the pilot light will light with no problem. the problem is,...
(More)
i have a propane, ventless type stove. the pilot light will light with no problem. the problem is, when the main burner kicks on it will work for a while then the pilot light goes out while burner is still operating, eventually everything kicks off. why would the pilot go out while burner is operating...i already replaced the thermocouple by the pilot light. it has one more thermocouple but it is built into the thermostat.
