Question about Minolta Office Equipment & Supplies
Cannot find fix to j3 error code minolta 2150
    Problem Solver:
  • 10 Answers
Remove misfedd paper
Posted on Feb 13, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
What's your question?PLEASE HOW CAN FIX HP 5100 PRINTER CODE 53.13.03
These error occurred with the printer's memory in DIMM Slot J3 (as labeled on the formatter board). This may be unsupported memory.
To help you troubleshoot the error 53.13.03 appearing on the HP 5100 printer, please follow the steps given below:
- Press the Cancel Job button.
- Turn the printer OFF, and turn it ON again.
- If the message returns, check the memory DIMM in Slot J3 to ensure it is supported memory.
- Move to a different memory slot to determine if the slot is bad.
- Reseat or replace memory in DIMM Slot J3.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-bpl11648
If the message persists, contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/support.html
GuruAid.com
Jun 02, 2016 | HP Office Equipment & Supplies
Error code 008 on indesit wixe127. What is it and how can i fix it please?
F08: Wash Heater Relay Stuck (signalled in presence of empty) or pressure switch stuck on Full (simultaneously empty and full)
- Check efficiency of J3 connector contacts on card
- Check pressure switch status by checking ohmic continuity on wiring connector J3 pins 2 and 4 (it must only be present with
tub empty), pins 2 and 3 (it must only be present with water in the drum) and pins 2 and 1 (it must only be present with water in the tub above normal level, more than halfway up door glass).
- Check wiring J3/pressure switch
- Check connection of heating element J3 connector pins 5 and 6.
- Replace pressure switch
- Replace Card
Dado
Dec 27, 2014 | Indesit Washing Machines
How to fix a error code 1327 on a minolta minolta bizzhub250
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Apr 08, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
C450p error c-2150
no such code but there is a 2151?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 06, 2014 | Konica Minolta bizhub C450P Laser Printer
Installed new toner cartridge into the machine. Still getting the J3 error
Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Nov 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
My minolta error code says J3, which has something to do with the flags. How do I reinstall the plastic flags?
Verify the exit part actuator,is damaged,J 3 paper jam in exit section.The exit actuator is located after fuser unit.
Mar 03, 2013 | Minolta EP1030/1030F CS/PRO Copier
Error code j3 for ep 1030
j3 - exit jam
search for a lever at the exit point of the copier, you sould be able to see the sensor at the lower part of the fuser. I may bejamed or the flag broken.
Nov 12, 2010 | Minolta EP1030/1030F CS/PRO Copier
Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Nov 11, 2008 | Samsung ML-2150 Laser Printer
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
These error codes indicate a
problem with the mirror motor circuit
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
assembly. Check the continuity of
the mirror motor cable connected to
J3 on the engine board. If incorrect,
replace the cable. The voltage at
J3-7 measures approximately
+24 V dc. If incorrect, replace the
engine board. If correct, replace the
FRUs in the following order:
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
54 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
