My train air unit cools at night but during the heat of the day it takes all it can do to keep the apartment around 80 degrees the maintnance man at work said the low pressure was at 80 and the high was at 350 which he said was a little high but he dont know why he did mention something about a txv some kind of valve but i really think hes lost please help
The pressures arehigh no doubt about it.
help your tech out then if you think he's lost.
go to the store and buy a couple of cooking thermometers.put one in the supply vents, the ones that blow.put the other one in the return vent, the one that sucks.may as well pull the filter out to temporarily...that way you can check it to see if it is clogged.
set your t'stat low so it should run for awhile.after 10 minutes run time record the return temp from the therometer.right after that do the same with the supply.subtract the return temp from the supply temp.you should have 17 to 20.this is your temp split.do it again after 30 minutes running.should be the same.
do it again when you are home during the time of day when your machine is struggling.if you dont have that 17 to 20 degrees difference, your a/c comp shut off due to a h.p. switch or o.l. switch.if these switches open, the fan on your outdoor machine will still run unless it is ruud/rheem.these switches reset themselves after time, unless it is a ruud or rheem,or lennox.
another possibility is that the evap coil iced. you the tenant can check this easily too.you will notice it this way...go to the supply in the grills in the morning, the ones that blow. put your hand up to them and kinda remember how hard they blow.do this again when you notice your a/c struggling during the hot part of the day...if it is weaker the evap coil is icing. if nothing at all, then it is probly totally frozen or your indoor blower is shuting off due to an o.l. switch.it will reset when it cools for awhile.dirty filters can actually cause both of these problems.
make sure your tech waits 15 minutes before he just says the readings are high. the machine needs to run awhile.if your apartment is boiling, this can make the pressures a little high.in the meantime he can check your temps.if your a/c coil is dirty, the machine out side...pay him to clean it.all he needs is a garden hose.this should help lower pressures a bit.
but in my opinion, you probly have multiple problems contributing to this. the first is lack of maintenence. the other is air and non-condensibles in your refer/freon lines.
Posted on Dec 29, 2008
  • 41 Answers
With that reading on the psi it sounds like it's doing all it can. maybe too small or lost it's capacity to cool your home.did it do ok last year? is the ducting ok? may need a pro to ck it dan
Posted on Jul 24, 2008
Why does ac go to 80 degrees when set at 76
Sounds like you need another opinion from another AC man. If you are in an apartment complex, it has been my experience most apartment techs have limited knowledge of what to check. Try this
1. With the unit on, go to you air filter and check for proper air flow. If you are using pleated filters, stop. Use what is called 30 day throwaway filters. Pleated filters block 35 % of the air flow and can cause evaporators to freeze over. Ace hardware still stocks the ones with the blue mesh with cardboard edges. I have used the same filters for over 2 years. All I do is use my vacuum cleaner and clean the dust bunnies collected every 30 days.
2. Perform an sight inspection of your duct system. I have had several customers whose duct have fallen off and they were air conditioning the attic space and/or crawl space.
3. Have your AC man determine your superheat and subcooling value for your airconditioning unit. If your AC man does not know what these are then he really isn't an AC man. A typical value for most superheat (SH) and subcool (SC) is 12 to 15 degrees. These values are typically normal values but can change due to design criteria established among manufactures. If your AC man does not know what these are or can not measure these you need to get someone that know how to obtain them. These values are typical value for a normally charged equipment and does not vary from refrigerant to refrigerant.
Hope this helps.
Jun 26, 2014 | Goodman Heating & Cooling
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
Jul 07, 2017 | Goodman Heating & Cooling
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
Mar 01, 2017 | Maytag Heating & Cooling
The Cool mode wont cool. It's just like fan mode. I cleaned all the dust off the panels and still wont blow cool air.
First the weather is extremely hot mid 90's and humid.I have a Trane combination a/c heat pump system. The A/C was pumping out warm air.I called for a technician and the problem was the compressor was not working.The solution/fix was to replace compressor start capacitor.The technician was here for about an hour.The compressor was running before he left however I informed him the air coming out of the a/c ducts after one hour of run time did not feel as cool as usual. It took from 1pm until 10 pm at night to cool the house air down to 80 degrees and the system ran constantly.I left it on 80 as that is where I usually leave it. Today again it is running all day barely able to keep the house at 80.My home was built in 07 block house, well insulated with thermal double pane insulated windows.I suggested to the tech to check the refrigerant level but he did not think it necessary and did not perform the check while here. The unit will cool the house down to 80 degrees but runs constantly.My question is: Should I have a technician come check out the system to insure proper refrigerant levels and pressure????????
Jul 30, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Indoor unit temperature between 60F & 70F after R22 charge..
The pressure changes with temperature, it is not a true gauge to ensure a proper charge.
You should have a 15 to 20 degree temp drop across the evap coil. (return air vs supply air)
Can you verify that the compressor is running?
Not the condenser, but the compressor located inside the condenser (outdoor unit)
it really sounds like it is still undercharged.
Check the temp drop, let me know what it is.
Also tell me what the outdoor ambient temp is.
( for example.... 98 degree outdoors with 85 degree indoor temp could result in pressures something like 325 on the high side and 75 or 80 on the low side.
With the exact same unit, but 80 degree outdoor temp combined with 70 degree indoor temp, your pressures could read 215 low side and 55 low side. Not to mention that more efficient units often have higher pressures on the low side because they have more coil space and remove heat more efficiently)
Aug 21, 2009 | Sanyo Split System Air Conditioner
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
Air Handler Blower
if you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Cools only at night
Possibly low on gas . Take Thermometer and check the outgoing air. Should be close to 45 degrees If not low on gas. Rusty
May 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
