Question about RCA Universal Remote Control
Need code ok, do u have the # to the company?? i have two of the same remotes n no code sheet
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): need code - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Need to program a univ. remote for LG model # 32LC20U-UE? I don't understand what more info you guys could possibly need? Are you guys a real company?
Sometimes its easier, although more expensive getting the correct remote direct from the Manufacturer however, most universals will work OK. If you have the manual or product sheet with the new remote, it should show you which code and how to program it . If that doesn't work, there should be an auto scan function which will cause the universal remote to run through every code until it "locks" onto your TV frequency. Have a good read of the instructions, it should show you how to do it. Good luck
Apr 10, 2016 | LG Televison & Video
I need a 3 digit code to set up another remote control for our cable
Best to at least recommend the obvious. You should look at the panel underneath where the battery is see if there's any numbers. Any model codes will allow you to enter something into a Google search with "remote control codes". This will allow you to get some possible code option sheets tables that work with your product & devices. This yields results in most cases that I've tried.
Jan 15, 2015 | Televison & Video
I have an RCA RTD615i DVD Home Theater System and i bought an rca universal remote. none of the codes i use are working. why is that
Those codes are developed by the universal remote manufactuers. Now if a company builds a remote before a comany builds a machine they will not have the codes to list on their code sheet. You should check the manufacturer of the universal remote for an updated code list
Oct 11, 2013 | Audio Players & Recorders
I need an instruction sheet for remote control r130a1. cannot access CC
Hello
The model number of Remote Control you specfied on your Post at Fixya is not clear to understand. If you are in need of RCA Universal Remote Contol's instruction sheet and codes, I've with me the same as an adobe acrobat document. Is it your need, send me your email address in reply, and I'll send it to you through yahoo, as an attachment. OK.
Nov 28, 2010 | RCA Televison & Video
I have a dish TV system; remote control is 4.0 IR/UHF PRO Cannot find the code to program the satelitte remote to turn TV on/off or volume.
which satelitte company are you with? You may be able to go online with the company you are receiving salelitte from and they can offer you a code sheet either on line or pick one up at one of their facilities. Or just lookup on a search engine 'program codes for satellittes". Hope this helped
Aug 17, 2009 | ViewSonic NextVision N2010 20 in. LCD...
Disney Cars
Unfortunately, there are no remote codes available for Disney electronics because the company that actually manufactured the TVs and DVD players carrying the Disney name was a no name company that didn't bother working with the companies that manufacture universal and cable remotes.
Jun 27, 2009 | Disney 13" TV
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
