Question about Bernina Artista 180
How to load bobbin into bobbin holder - Bernina Artista 180
  • 202 Answers
When you have the bobbin wound and placed in the bobbin case pull on the thread. If the bobbin turns counter-clockwise the bobbin is in upside down. The bobbin must turn clockwise when you pull the thread looking at it from the back..
Then slip the thread into the notch and pull it up under the flat spring up into (through) the hole.
Thats it, now snap it in the machine.
Posted on Jul 24, 2008
The directions are very vague about how to thread the bottom bobbin. I have no idea how this is to be done or how the needle will pick it up. Help Please!
you don't thread the bobbin as such
wind sufficient thread on to the bobbin (use the rewind section of the machine )
place the bobbin in the bobbin carrier in such a manner that the thread unwinds anticlockwise
take the thread and pull it around the edge of the bobbin holder until you reach the slot in the holder
pull the thread down that slot and under the flat spring plate at the bottom of the slot
That plate controls the tension of the bottom thread
pull out about 5" of thread and while holding the thread put the bobbin holder and the bobbin into the machine making sure that it goes right in and clicks in place ( turn it to achieve the click
The needle should be fully up for this procedure
now thread the needle and hold the end of the thread while you hand turn the machine in the sewing direction
the needle will go down and if not on the first time will on the second time pull up the bobbin thread
pull that bobbin thread up and place it along with the needle thread under the foot plate and out the back comment if that doesn't work as there may be a bigger fault that can be fixed
May 27, 2016 | Sewing Machines
I have an elna lotus sewing machine and have refilled the bobbin but cant remember how the bobbin goes back into its place. the machine will sew for awhile and then the cotton gets tangled .can you help...
Is this a Swiss made Elna Lotus with top loading bobbin (check machine plate on right beside power inlet for manufacture details) ? (the original Lotus was released back in 60's but that name has been reused on a number of different models since, some made under licence elsewhere) If yes, then the following applies:
Bobbin should have holes on one side only, always wind it with the holes on top and load it into the bobbin holder the same way so it is rotating anti clockwise when you pull the thread.
Drop wound bobbin into bobbin holder and, while holding the bobbin still with one finger, pull the thread tail towards you into the tension spring, then press down on the thread until you hear it "Click" into the tension spring.
Then hand wind the fly wheel towards you while holding the top thread tail to catch the bottom thread and bring it up to the top needle plate, close the back sliding plate over the bobbin.
Other thing with these machines is ALWAYS hold the two thread tails firmly when you start a new seam so the threads don't get pulled down into the bobbin holder area. Really important.
You can dowload a manual from for most of the Swiss machines.
If it is not Swiss made one, then your bobbin may be vertical front loading (like the Brothers).
There are threading diagrams for lots of machines at, there might be one there that covers your machine.
May 22, 2011 | Elna Sewing Machines
I am having problems with my bobbin. Every time I load it and start to sew it gets jammed and the needle stops. There is a mess of thread around the bobbin.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | White Sewing 2037 Mechanical Sewing...
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
Trying to use and bobbin keeps tangling up with loads of thread
Oil the bobbin holder. Wipe small amount of oil on outside diameter of bobbin holder. Replace.
Also try using better quality thread. Some thread is not consistent in diameter or has lots of small fibers - it will not got through the eye of the needle easily and will become tangled.
Nov 19, 2009 | Brother LS2020 Sewing Machine
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Bobbin threading
Unthread the machine
Open the top of the machine and take the thread and place it through one of the whole in the bobbin (from inside to outside) and pre-wind to secure the thread around the bobbin
Wrap the thread around the far left feeder knob on the top and put the bobbin on the bobbin holder in the top right-hand side
Push the bobbin to the right until it snaps in place (it will click)
On the outside of the machine, un-secure the hand sewing wheel so that it is loose
Power the pedal and watch the bobbin load
When finished, push the bobbin holder back to the left to release it and you're done
Sep 14, 2008 | New Home 2014LE Mechanical Sewing Machine
Sewing Machines Logo
239 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
