Question about RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
    New Friend:
  • 103 Answers
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Posted on Feb 16, 2011
SOURCE:
Could my remote on key fob for car battery fail to open all doors apart from drivers had it to auto garage he said ineed new locks?
Usually takes two clicks to open all doors, right? Is there no sound on the second click? If not, I would suspect the receiver--not the locks.
Dec 21, 2017 | Cars & Trucks
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
CAUTION
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
Feb 23, 2015 | 2009 Chrysler Town and Country
How do I program a dvd player with the new xfinity x1 remote? The instruction manual does not tell us how.
It is my understanding the xfinity remote is designed only to control comcast set top box and TVs. It also can control audio receivers. It is unlikely you can control a DVD player with it.
At best you could try and use the programming instructions on page 5 of the manual and see if it picks up your DVD player. Otherwise it might be better to use the existing remote controller you have and program the Comcast set top box to it. You need to find the codes from the programming instructions of the original remote control and you will also need to know the model number of your comcast box.
Hope this helps.
https://x1.comcast.net/webportal/assets/pdfs/RemotePairingGuide4.26.11.pdf
Sep 12, 2014 | Televison & Video
Remote starter auto locking doors
it may be programmed into the remote as a safety feature.. ask the dealer..
Jan 21, 2014 | Cars & Trucks
My fobs need to be reprogrammed
because of remote start fob needs to be flashed at dealer
Jul 30, 2017 | 2006 Pontiac Montana
I have a bulldog remote starter on my truck and lost the remote. I want to know how to program a new remote to it??
it depends on your model, if you buy a replacement remote at walmart, it will come with instructions
Jan 10, 2010 | HON 1 T-harness Remote Starter Wiring
I need codes to program the key remote
You need a special computer for that. Either the Nissan service department or an aftermarket store that installs auto alarms, remote starters, etc, often have it and they can do the job.
Jul 08, 2009 | 2002 Nissan Xterra
RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm Logo
1,028 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Marvin
Marvin
handt729
Level 1 Expert
Kardoc
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
