Question about Refrigerators
Frezzer icing up in bottom of frezzer - Refrigerators
  • Anonymous May 01, 2009
    maytag frig freezer icing up. frig is still cold.happens every couple of weeks. i don't open up enough to have this problem
    maytag french door frig
  • 833 Answers
Likely caused by opening the unit too many times. Defrost completely, do not block air circulation.
Posted on Jul 23, 2008
Bottom frezzer keeps defrosting
Try defrosting the whole fringe top and bottom and make sure the ice build up in the crossover vents is all cleared out. Ice keeps the cold from moving through the fridge as it should.
Try this before you do anything else. simple things 1st.
Mike
Jun 11, 2017 | Refrigerators
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
Not making ice fast enough
frezzer must be about 5 deg for ice mker to work . some models have a fan to speed ice production .. .. ck thes things . and adjust freezer tempt . .. also clean the cond coils . if dirty cooling is poor .. mm hope this helped .. feed back pls ..
Jul 10, 2011 | Samsung RF265AA Bottom Freezer French Door...
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice froming at the bottom of the refrigirator
Check that the drain is clear. If it is blocked water will back up and spill on the floor and can potentially freeze. Otherwise you may need service to install a drain heater.
Jun 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
