Question about Xerox WorkCentre XD100 All-In-One Laser Printer
CODE U2 THE PROBLEMIS A U2 CODE WHEN IM POWER ON THE MACHINE
    President:
  • 2,072 Answers
A U2 is related to a memory failure. May be a bad memory chip or main board. BUT, before we get drastic and move in that direction there are a couple of other things that I have seen cause that.
So, first I have seen the chip on the back of the drum cartridge cause that problem. You can try removing the drum cartridge and powering on the machine without that installed. See if it just comes up with a J2 code then. Or even a CH code. If the code changes you may simply have a failed drum cartridge.
Sometimes memory corruption can occur and you can clear it using this procedure..
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Jul 24, 2008
  • Rick Kasper Jul 24, 2008
    If that doesnt resolve your issue, you will probably have to replace the main board. Go on google and look for a place called The Parts Drop. Call them and talk to Britt and see what he can do for you from there parts wise.
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
Oct 16, 2014 | Sharp MX-2300N Color Copier
U2 91 code
This code may clear by simply switching the machine off via its main power switch.
To reset it using a test simulation try the following:
# * C * then type 16 and press your start / copy key. This should reset the U2 code.
The error is a PCU check sum error.
Jan 22, 2014 | Sharp Copier Toner AR-M350 450 AR450NT
CalL for service U2-20
Thats a odd one.
That means the machine speed is programed wrong.
Try pressing # * C * , that will enter diagnostice.
Enter 16 which is U2 fault clear and press start, then press 1 and start. DO that a couple of times then press the yellow clear and hte machine will reset.
Or power the machine off and on.
Did you replavce a board or software? Thats a weird code to just pop up.
Nov 05, 2010 | Sharp AR-235 Copier
U2-40 code
CLEAR THE ERROR
Enter SIM
# - * - C - * - 16 - START
Mar 31, 2010 | Sharp AR-M237 Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Sharp AR-285 Error Code ''U2-00'' What does that code mean and can I fix it locally?
A U2-00 is an internal error code from the main processing board's EEPROM (the chip that stores your configuration choices, the copier's serial number, etc.) It can be a faulty EEPROM but most likely the copier took a power hit/glitch and the fault needs to be reset.
To clear the fault make sure the copier is in Copy mode, then press the 'P' key, then the 'Interrupt' key, then the Clear (C) key, then the 'Interrupt' key. This will enter the machine into simulation mode.
Now enter the number 16 and press start. The machine may also ask you to confirm your choice or you may have an 'execute' key on the LCD screen.
Once the fault has been cleared the machine should reboot. If it doesn't, press the 'CA' (clear all) button and the machine should reboot.
If the U2 code persists, you need to call a repair technician to facilitate repairs.
Sep 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
584 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
