Hi
I have the LEGEND LEC3220. The LCD needs main board, as color is no longer working properly.
I need the following part: 667-L32U25-56L CPU Board Assembly. Do you provide? If not, where can I get one.
Thank you.
SOURCE: Tatung V30DMTT 29.6 in. LCD... Problem: Faulty Power Board
Hi -I had the same problem with my tatung LDC tv. PIECE OF !@$#$#@#!!. Not knowing a whole lot about electronics, I decided well, I couldn't break it anymore, and I thought it was probably the power supply as the tv did NOTHING!!! it wouldn't light up make noise or anything. it was totally dead. I called around MANY, MANY local tv repair shops and NO ONE would work on this as they didn't have the repair parts for it. Thats what I get for going cheap. Anyway, well, I popped the back off, carefully making sure I knew where each screw went if I ever had to put it back together. Well, I located the power supply - it's pretty obvious, I removed it with a few screws and then found a company in california that repaired power supply's - I sent it off not knowing if it would solve the problem, but they quoted me $75 dollars and I figured if it didn't work $75 wasn't too much of a loss - and they said I could return it and get some of my $75 bucks back. So, I shipped it off to them. A couple weeks later, I got it back and installed it and to my amazement it worked!!! It has been working GREAT ever since. There is a few places online that sell the power supplies and offer a refund minus restocking fee if that doesn't work. Check out http://www.shopjimmy.com Good luck and hope this helps scott
SOURCE: system board replacement
Leadtech described how to remove the back panel. However, after removing all the screws the panel does not easily come off. Do you need to pry off the back panel?
SOURCE: Right third image filled vertical lines when hot
Ive Had the same issue with my TV - and its really dissapointing to see it so well documented - obviously this is a design fault- its the last Philips TV im buying :(
SOURCE: Need help finding an Akai LCT2701TD Power Supply Board Assembly
It seems like there are not many of these service parts available anymore. The only way to get your LCD working again will be to repair it.
The repair involves changing the defective parts to restore the LCD functionality.
If you need more info, you can write to [email protected]
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail [email protected]
