Question about Sanyo Refrigerators
Need to locate a rubber seal for a Sanyo 10.3 cu ft top mount refrig
  • 41 Answers
1-800-698-1049 jacoby apliance parts dan
Posted on Jul 24, 2008
Where do I find the location of the run capacitor for the LG LMX25984SW refrigerator ? thank you
motor capacitors are big and usually attached to the outside of the motor. However, refrig compressors are often sealed so one cannot access the capacitor.
Dec 01, 2016 | LG LMX25984SW 24.7 Cu. Ft. 4 Door French...
Need box specs for Alpine dvc type r 2ohm 12"
  • frequency response: 24-200 Hz
  • power handling: 300-600 watts RMS (300 watts per coil)
  • peak power: 1,800 watts
  • sensitivity: 85 dB
  • top-mount depth: 6-3/8"
  • sealed box volume: 0.65-1.25 cu. ft.
  • ported box volume: 1.0-2.0 cu. ft.
  • Crutch field audio has a DIY section on box building ;)
Oct 20, 2014 | Car Audio & Video
Box specs for 10d2
this a a impedance-2 ohms speaker sealed box 0.54 cu.ft. and a ported box 1.04 cu.ft. top mountdepth 5 9/16in bottom mount depth 6 5/16" cut out dia. 9 1/16"
Nov 21, 2013 | Car Audio & Video
How many cu ft is it? need new seal for door hmg241770 admiral refrig
Not sure what the cubic feet for the doors for that refrig. but i have the part#'s for you
Fresh food gasket 61004010
Freezer door gasket 61004011
hope this is your looking for
Gene
Aug 01, 2011 | Kitchen Ranges
Refrig does not cool to only 45 degrees Freezer is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | GE 18.2 Cu. Ft. Top-Mount Refrigerator -...
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
R door- GE 21.6 is slipped down. Gasket cant seal, part needed?
the parts detective dot com has all sorts of repair parts. You'll need the model and possible the serial number.
Aug 11, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Refrigerators Logo
    55 people viewed this question
    Top Sanyo Refrigerators Experts
    John Tripp
    John Tripp
    christian nielsen
    Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
