Question about Kenmore 62872 Electric Dryer
Don't know if this is right model
I am having trouble finding info on the dryer I have because it is so old.. It's a Kenmore Capri electric front loader dryer. The way the model # read on the card was 86921100 69211. I am trying to find a dryer belt and a diagram so I can replace the belt.
  • Shrimp0981 Aug 20, 2008
    Just wanna says thanks I was able to find what I needed and my dryer works like a champ now!!
  • 5,911 Answers
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Posted on Jul 23, 2008
I have a kenmore 99701 series combo w/d. they tell me they are all 110. told them 220. neeed to know for sure as cord was taken off and screws missing and loose. don't know for sure and if grounding is...
Well for sure the washer is going to be 110v. Only electric dryers are 220v!. If your dryer doesnt have a gas connection on it then it is a electric 220v dryer. If it has gas connection then it is 110v gas dryer. there is no such thing as a 220v gas dryer!!!.
Mar 25, 2010 | Kenmore Washing Machines
Kenmore dryer model 110 63032101. The dryer only has low heat come out. It takes too long to dry the cloths. I cleaned lint in the front panel. What is the next step to look for and how to fix it? thanks.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. However I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. If you have an error code you can probably find the meaning of it there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 26, 2009 | Kenmore 63032 Electric Dryer
Model 84152 beeps and won't start
probably the thermistor is bad. located on the blower housing in front of the motor nest to the thermostat. if you tilt the console back(remove the screws at either side, either visible or under snap off console ends) there is a tech sheet wiring diagram to trouble shoot the circut. unplug it first...
May 24, 2009 | Kenmore 84152 Electric Dryer
My Kenmore dryer is not heating. Need to check heating element.
Hi, You need to remove the front lower panel. There you will find the element on the right side under the drum. If the element checks out ok, then you need to test al the thermostats and the safety fuse. With he dryer unplugged, check all these parts for continuity. If any of them show no continuity,replace it. If I can assist you further, please let me know.
Thanks
Vic
May 16, 2009 | Dryers
Dryer won't heat
Hi! donj56
There are a lot of challenges in checking the electrical system. If this dryer has a traditional timer it is best to find the circuit diagram included inside the dryer. Consult the diagram and make sure you have the same voltage on the input of the timer and then on the circuit feed to the igniter. The case is a good ground so you do not need to connect to the Neutral. Let me know the dryer model number? Is the dryer in a high humidity environment? Also, how old is the dryer?
Oct 30, 2008 | Kenmore 74602 Gas Dryer
Kenmore Elite dryer
possible interface bd(front controls)there is a lot of electronics on the back side the relay bd on top left receives most of it's commands from front controls if your husband knows how to ck things pull bottom panel off there is a tech sheet on backside..may even ck thermistor on blower housing for correct readings
Jul 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Squeeking noise
Here's a possible troubleshooting fix I just sent to someone else that quite possibly has the same problem you have there now.
Hope it helps you out as well, as it is a bit long, but I'll post the whole reply I sent them and you can use whatever parts of it that will work for you.
My name is Frank...
Regarding your possibly broken dryer.
I'm hoping that this info below helps you out even though I know I won't be able to repair/fix your dryer myself personally. Reason why - I'll explain further down.
I've repaired a few gas dryers & washing machines as well in my time. I can honestly say that I'm as close to being an expert as they come - esp when it comes to making repairs on existing dryer parts that can no longer be purchased as they are either obsolete, or way over-priced.
This is what I do for a semi-retired hobby, and sideline self-employed FIX-IT business. Named appropriately - FRANK'S FIX-IT SHOP. It's only an online fix it at present. Keeps me busy instead of being bored to death.
Electric clothes dryers are typically made the same as gas dryers - as to the mechanical drum part. Only thing different in a gas unit is the 110VAC electrical igniter or element, and the gas delivery system that provides the drying heat to the dryer itself.
All else is basically the same...
In an electric clothes dryer all the power comes from the 220VAC source as to the heating element, etc. The mechanical parts are typically the same as that of a gas dryer.
Having said this - the problem with your dryer can only have one of possibly 2 things wrong with it - seeings it's no doubt 220VAC totally electric, unless you actually have gas where you are there, which is rare in Florida these days!
If after you start the drying cycle you quickly open the dryer door, and you notice the drum is actually rotating - until there is the loss of electric power via a safety door switch that kills electric power to the drum motor activity - then there is NOT a problem with a broken drum belt.
If your dryer is older then say 10-15 years, and you really use it alot - then maybe there's a possibility of a broken drum belt (cost is around $10-15 for a new belt part depending on model - usually - and that does not include labor to install it).
Usually you'll hear the motor whining, but no drum 'noise' or movement. Dead giveaway as to a broken belt.
I had replaced 2 belts and 1 IDLER wheel on my own 30+ year old gas Kenmore dryer before selling it, and then picked up a more recent newer model GE washer & gas dryer that someone was just giving away for free. My 30+ year old Kenmore washer had just died on me at the same time is why I upgraded. Can't pass up a great freebie deal like that everyday! Never had to fix anything on my Kenmore washer during the time I owned it - it was GREAT!! I miss it dearly now.....
Though they were both newer GE models I really don't care for GE anything, as I think they are poorly built, as well as is their refrigerator brands as well.
Don't buy GE anything if you don't have to!! You heard it here from me and I know. My GE washer already broke a belt not even being 8-9 years old, and it was hell to replace, and never worked right afterwords as for the water pump part. Very POOR design! Oh well...
The gas dryer works fine, but the lint collector is not anywhere as good as my old Kenmore was. Poor design in my opinion.
I'm looking for another Kenmore or Whirlpool (set) model now, as they are the best. Kenmores are made by Whirlpool btw, just in case you didn't know that. The best in the business!
As to your other possible noise scenario -
The only other weird noise scenario you'll experience if it's a Kenmore dryer is when the drum "spring loaded track IDLER wheel" goes bad. This drum IDLER wheel is located under the drum itself at the back part of the drum and rides in a groove in the drum itself. It also helps to stabilize and counter-balance the drive belt-loaded turning drum that rides on this drum IDLER wheel as it turns. If your dryer does have the rear drum IDLER wheel system, then it just depends on the make and model. Kenmores & Whirlpools are designed this way. Very good design I might add!!
Some, or all GE dryer models may have a rear drum centering bearing assy instead - and in addition to - a front (Support, 3 glide front drum bearing part# 2359 & a Drum front slide bearing part# 2305 times 3 needed). If this/these front support/slide bearing part(s) goes bad usually the "felt duct" will need to be replaced as well. It not only helps to seal and quiet the drum that runs on the Support part, but it also helps to keep clothes from getting in-between the Support C part and helps prevent clothes from getting damaged. If those (3) friction sliders wear out or fall out, and take out or damage the "felt duct" as well, then the noise will be horrendously LOUD.
The front part of the GE drum models usually rides on a separate front panel support assy which can be made of a plastic C shaped device with anti-friction pad strips to help in frictionless rotation of the drum. A cheap but pretty effective design that does away with a front IDLER wheel, or pair of IDLER wheels as it were at the front of the dryer's frame which houses the door assy as well.
Though my Kenmore replacement drum IDLER wheel only cost me around $17 many years ago I see they now are anywhere in the $30+ range. Ouch! If it's the GE rear bearing assy that has gone bad - another Ouch as that part runs around $50+. Just depends on where you are and parts availability.
Most Kenmore/Whirlpool model dryers with the rear spring loaded drum IDLER wheel design do not have a ball bearing design, but rather have a typical cheaper brass bushing design instead, and when the grease lubricant dries out or they become dirty from picking up dirt in the air such as lint from the drum, etc then they begin to SQUEAL or WHINE very loudly.
The longer this goes on like this the hotter the drum IDLER track wheel gets until it melts the "typically" molded plastic housing, and then it really makes a lot of noise, and could actually lend to the drum belt breaking - as due from the added friction & stress from the binding wheel. It can also damage the front "felt duct" material as well. I had to repair mine as best I could as they had n factory replacement part that I knew off.
The only other mechanical parts that could possibly make any squealing type noise would be the electric belt drive motor or the heat blower motor being gas or electric. If the heat blower motor uses a cheaper brass sleeve shaft bushing bearing that would be rare, but could be a noise source as well. The belt drive motor rarely rarely would ever go bad!!
I hope this info helps to narrow down your problem if you are not able to at least open the top up to inspect the dryer yourself. Always unplug the 110VAC power before opening any cover or panel part up though!
That will not only prevent any electrical shock hazard, but will also keep the gas from turning on by mistake - as by solenoid design - if your dryer is gas.
I suspect this is what's wrong with your dryer.
Again - I hope the info helps you out...
Best regards,
Frank
Feb 09, 2008 | GE DBXR463GB Gas Dryer
Kenmore 62872 Electric Dryer Logo
415 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
