Question about Kenmore 15864/15862 Top Load Washer
Kenmore 90 Series Washer Noise--Won't spin
Model 22912 100
Washer mortor runs (makes a loud sound--not grinding noise but a loud low whine or roar) but won't spin--it is NOT the coupler though. Any thoughts?
  • 1 more comment
  • tegres Aug 01, 2008
    When the water is running for the fill, wash, and rinse cycle, there's a loud low vibration humming noise. If I turn it off and back on again, the sound would go away, sometimes, but eventually come back. Is this the washing machine or my water pipes? Would this cost over $100 to fix?...if so, I would probably get another washer, right? -TE
  • anderd22 Jan 15, 2009
    My Kenmore washer Series 90, app 15 yrs old, also fills and appears to go thru all the cycles, BUT no spin or agitator and fairly loud whinning humming noise.. Thanks
  • Anonymous Mar 22, 2014
    washer spins but makes loud banging noise like unbalanced but isn't
  • 550 Answers
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Posted on Aug 19, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
525 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
