Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner
Problem for Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner
It turns off
By cepi44 on Jul 23, 2008
it has been working fine, but since a week ago, i turn it on and works fine for a few minutes and shots off and displays a "E1", i reset it , turn it back on and does the same thing, how can i fix that?
Same Problem
Jul 25, 2008
-   our sharp unit AF-S85FX flashes code E1- we cleaned filter but unit won't reset.-   cindy787
Best Solution
posted on Jul 24, 2008
Very Helpful)
spam_here
Rank: Guru
Rating: 90%, 100 votes
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Sharp AF-S100FX 10,000 BTU
Questions and Unsolved Problems for Sharp AF-S100FX 10,000 BTU
Do you recommend Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner?
Answer
Answer
can some one help looking for operation manual for amac 12000 portable a/c unit
Answer
Thefan motorwarms up but does not runs
Answer
fan of my wall air conditioner is not moving
Answer
my Air conditioner suddenly off and light in timer and air flow picture is on. when I want to On my... (More)
Answer
Sharp AH-APO9EVA plasma split unit air-con 2 years old compressor keep stopping every few minutes... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AF-S100FX 10,000 BTU...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
