Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
Menu pasword Hi Ive recently aquired a used SRH-2162 DVR the problem is the menue has been password protected & we have no idea what it is is there a reset or overide to reset the password
  • 1 more comment
  • Anonymous Mar 19, 2014
    Password invalid
  • Anonymous Mar 20, 2014
    some guy put a password on it during installation but forgot the password. Cant access my setting or configure my Dvr. What should i do?
  • Anonymous Mar 25, 2014
    my DVR is block , i need to reset the password, i forget it
  • 149 Answers
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
Posted on Oct 02, 2008
  • john lancheros Jul 20, 2012
    que hago despues de restablecerlo
  • Raph Kibambe
    Raph Kibambe Jun 08, 2016
    i forgot my tiandy pass how to restore to defaul?
Hi!...
You should to tell your problem to Samsung's support section, they're very fast answering.
This is the contact info:
menu pasword - cleardot.gifMartty Moon mmoon@gviss.com
Gretings!
Posted on Aug 19, 2008
How to reset dvr ws-7008 to paswords default
Posted on Jul 03, 2013
PASSWORD IS ALWAYS IS "4321"
Posted on Oct 22, 2008
Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Jun 15, 2015 | Home Security
How to reset hi-focus h264 dvr admin password?
173480
8456Hl
375611
Please use above the Master Password. This password is only valid for today.
Kindly use the master password from VGA/HDMI.
Kindly follow the below procedure to reset the password:
Remove LAN cable if it is attached
Restart you DVR
Choose the "admin" account in USERNAME
Use MASTER PASSWORD in PASSWORD. Now you can access your DVR
Go for Main Menu >Advance > Account
Select "admin" user
Click on Modify Password, In Old Password Use Master Code,
In New & Confirm Password type your new password (without any special characters).
Now you can login with your NEW PASSWORD that you have created.
Oct 08, 2014 | Home Security
Dvr password reset
see hte following link below. you need to set the DVR back to default in order to reset the password.
http://www.safe-n-secureinc.com/Support/Samsung/Samsung%20SHR-2160-2162-2080-2082-ENG.pdf
Nov 06, 2013 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I have a samsung who forgot pasword, how to reset the pasword
There's good news and bad news. The good news is that you might well have forgotten that the default password on the Samsung phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.
First, here's what Samsung says about working with passwords on the Security
Use this menu to protect the phone against unauthorized use by managing the several access codes of your phone and SIM card.
Note: If you enter an incorrect PIN/PIN 2 three times in succession, the SIM card is blocked. To unblock it you need to enter your PUK/PUK2 (Personal Unblocking Key). The codes are supplied by your network operator.
PIN check
The 4-to-8-digit PIN (personal identification number) protects your SIM card against unauthorised use. When this feature is enabled, the phone requires your PIN each time it is switched on.
Change PIN
Use this menu to change your PIN. The PIN Check feature must be enabled to use this feature.
Phone Lock
The Phone Lock feature locks the phone from unauthorised use.
When this feature is enabled, you must enter a 4- to 8-digit phone password each time the phone is switched on.
The password is preset to 00000000. To change the password, use the Change Password menu.
Change Password
Use this menu to change your phone password. The password is preset to 00000000.
Privacy
Use this menu to lock your media contents, including MMS messages, emails, images, videos, music files and sounds:
1. Press [OK/i] to check the item(s) to lock.
2. Press Save to lock the marked items.
3. Enter the phone password and press OK.
To access a locked item, you need to enter the phone password.
If that doesn't help you, as I said, you'll need to take your phone to the local service center and ask them for help. Just a tip: bring some sort of proof of purchase or ownership so they can differentiate between you losing your password and someone else showing up with a stolen telephone.
Jul 13, 2011 | Cell Phones
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
How do i reset the password on my Divar so i reset the language and watch my recordings
Connect a monitor directly to the Divar video out (mon A).
Turn on Advanced menus.
Scroll to the connectivity settings and you will find both the network setup menu (which must be set correctly for your network) and the user/password table. Set the ADMINISTRATOR password there.
Aug 22, 2010 | Bosch DVR-16E-2162 Video On Demand Video...
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
6,818 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
