Question about Lite On LVW-5007
No response
Unit will not respond to any commands after the initial "hello." I have tried plugging and unplugging, leaving the unit unplugged for a number of day and then replugging and still no response either with the remote or by pushing any of the buttons. There is a dvd stuck inside that I would like to rescue. I there a solution?
  • Anonymous Nov 30, 2008
    Our
I had a similar problem I simply removed the cover (about 4 phillip head screws) and the cover plate of the disk drive(just pull it off) and removed the disk.
Ensure that the drive is not jammed by moving the drawer forward as if it would when it opens.
Replace the disk cover and close the case using the phillip head screws. Plug it in again and let it boot up. Try opening the door by pressing the eject button. It should work.
This worked for me. I have a bad drive and want to replace it so I explored a bit on how to remove it.
Posted on Mar 02, 2009
Our dryer does not function after a slight power outage due to an electrical storm. The number 88 blinks for a minute then goes to 18 . There is no response to the control panel , no buttons work!
brand and model numbers would be very helpful. without this info, I would try unplugging, wait about a minute, then plug back in. sometimes units can be reset by just cycling the power. Good luck.
Aug 05, 2017 | Dryers
Unit turns on but does not respond to commands.
take the cover off and locate the humming noise...is there a belt loose?
Nov 25, 2013 | Sony MegaStorage CDP-CX455 400-Disc CD...
Hello I have the model JMV1540LNCS, and there was a problem with the electricity at my house and now is blocked.. it is something serious? is new it was just installed last week. I touch the front panel...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
May 04, 2010 | GE Microwave Ovens
F70 Error Code after initial wash. Unplugged
Hello there
Here is your Answer
Error code 70 means a Central Control Unit Heartbeat Failure. There is no
communication detected from the Central Control Unit to the
User Interface (the part that you touch in the middle to set cycles).
Possible Causes/Procedure
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and
the Central Control Unit.
If these connections are ok then
3. Replace User Interface if drum is rotating. Part number is W10164402
4. Replace Central Control Unit if drum is not moving. part number is 8183259
Hope this has been very helpful
best regards michael
Dec 25, 2009 | Whirlpool Washing Machines
Freezes
Leave it unplugged for 24 hours. Sounds like the failsafe for a power surge. This is typical for RCA products. I have a 54 inch rear projection TV that will only tune 16 channels and none of them are correct when it surges. The solution: 24 hours unplugged. I also have the same type of thing with my RCA DVD recorder... Never had it happen to surround sound, though.
Sep 26, 2009 | RCA RT2380 Home Theatre System System
I just purchased a RCA model # RTD315w watched only two movies and now the unit wont respond to anything. Still have a movie in the unit that Icant get out because the unit will perform no function. I...
Possible solution that is not mentioned by customer service- is just a small thing- unplug unit- let rest for 30 mins, HOLD POWER BUTTON DOWN FIRST THEN PLUG BACK IN- hold for 30 secs, unplug for 30, the plug back in.
Mar 16, 2009 | Audio Players & Recorders
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Jan 18, 2009 | U-Line Refrigerator Ice Maker
Giving -F3- display and beeping 3 times, does not respond
If that doesn't work, you have a shorted / failed membrane keypad.
Until it is repaired, please leave it unplugged or leave the door open.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jan 11, 2009 | GE JVM1850 1000 Watts Microwave Oven
Won't respond to remote
Access servicer menu,run initial set-up. Have you already tried hard re-set? Leave it unplugged from AC overnight==== Also,please verify model #
Oct 05, 2007 | Sony KV-36FS100 36" TV
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Lite On LVW-5007 Logo
99 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
