Question about ASUS P4S800D-X (610839122325) Motherboard
Adding More Memory
When I started using this MB I had 2 512mb PC3200 DIMM's installed in DIMM A1 [blue] and DIMM B1 [blue] these worked with no problem.
Later I decided to add more memory and as I only change 1 area at a time when making changes, I removed the 512mb DIMM's and installed 2 1gb PC3200 DIMM's in their place at DIMM A1 [blue] and DIMM B1 [blue] . They worked fine.
Then I installed the 2 512mb DIMM's into DIMM A2 [black and DIMM B2 [black]. When I started to boot up the monitor showed nothing at all except it's built in check saying the monitor was OK. Thinking I might have damaged the 512mb DIMM's I removed all the DIMM's and installed the 2 512mb DIMM's into DIMM A1 [blue] and DIMM B1 [blue] and they worked with no problem.
I cannot make the computer work with all the DIMM slots filled. I have heard that others had the same problem. What's the fix?
    Master:
  • 397 Answers
Reset the BIOS using the motherboard jumper before booting into Windows.
Posted on Jul 23, 2008
IN COMPAQ DL380G4 I HV SOME TECHNICAL PROBLEM WHEN I INSERT MEM PC2-3200R-333 THEIR IS NO DISPLAY . WHEN I REMOVED MEM I AM GETTING MEM BEEPS PLS REVERT BACK ASASP
Use below mentioned memories.
1GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2 x 512 MB)
343055-B21
2GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2x1024 MB)
343056-B21
4GB of Advanced PC2 PC3200 DDR2 SDRAM DIMM Memory Kit (2x 2048 MB)
343057-B21
May 18, 2011 | HP Compaq ProLiant DL380 G4 Server
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
Anyone know why an ASUS PTGD1-LA motherboard will only take memory in slots A1 and A1 or A1 and B1 but not anything in B with both in A filled? Brand new memory.
HI,
The board has specific requirements for memory. Here's the Memory Configurations :
  • You may install 256 MB. 512 MB and 1 GB unbuffered non-ECC DRR DIMMs into the DIMM sockets using the memory configurations in this section.
• Installing DDR DIMM. Other than the recommended configurations may cause memory sizing or system boot failure.
• In dual-channel configurations, install only Identical (the same type and size) DDR DIMM pairs for each channel.
• Always install DIMMs with the same CAS Latency. For optimum compatibility , It Is recommended that you obtain memory modules from the same vendor
• Double-sided x 16 modules are not supported on this motherboard.
• Due to chipset resource allocation, the system may detect less than 4 GB system memory when you installed four 1 GB memory modules.
For dual-channel configuration you may:
install identical DIMMs in all four sockets
• install identical DIMM pair in DIMM_A1 and DlMM_B1 (blue sockets) and identical DIMM pair in DIMM_A2 and DIMM_B2 (black sockets)
• install same size DIMMs in DIMM_A1 and DIMM_B1 (blue sockets) and another same size pair in DIMM_A2 aid DIMM_B2 (black sockets)
Hopefully this will help understand how to install the new memory.
Thanks Mark
Mar 19, 2010 | ASUS PTGD1-LA Motherboard
Extra memory
My manual for P4P800-VM says :-
Mode Dimm A1 DimmA2 DIMM b1 dIMM b2
single ch 1 populated
2 populated
3 populated
4 populated
Dual ch 1 populated populated
2 populated populated
3 populated popuated populated populated
for dual channel 3 configuration you may
install identical dimms in all four sockets or
identical in A1 and B1 [blue ]
and identical in dimm A2 and dimm B2 [black sockets ].
Probably same as yours
Good luck
64bvt
Jun 18, 2008 | ASUS P4P800-MX Motherboard
Burnt DDR DIMM socket
It may be possible, but the system may very well become unstable at times. The purpose of the different color dimms is either daul band memory and or hypertheading, which means the memory needs to be matched and in pairs to work correctly. I would try one pair in the same colored slots in which one of them is not burnt. Also can you get it to boot with one stick of ram in a slot? Have you seen this board boot at all with 1 burnt slot (Known Good Board). Hope this was informative to you. Good Luck, Let me know how it works out.
Jun 09, 2008 | ASUS P4P800-X Pentium Motherboard
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Memory slots DiMM A1&A2 does not work
Fixed the memory well and and insert the memory one by one.
first insert 1 memory and test, and then so on.
If not work work clean the slot and also the memory.
Jan 08, 2008 | ASUS A8N-E Motherboard
Memory pairs
no place them this way if one kind is kingston or whatever a1 b1 and the other kind makes no difference as long as their in the right sockets/ a2 b2 these should be colored so if you have 2 of one kind and 2 of another you would keep them in the perspective colors ?dual ram is usually done this way you would have 1 gb in a1 and the other in b1
Oct 08, 2007 | ASUS P4S800D-X Motherboard
ASUS P4S800D-X (610839122325) Motherboard Logo
200 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
