Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Programming lost manual how to program hunter thermostat 44260
Program a thermostat
Posted on Nov 01, 2008
Troubles setting up a thermostat
The work setting would be only used if everyone in the household has he same schedule. If everyone leaves @ 8am, then set the leave @ 8am. If everyone returns @ 5pm, set the return to 5pm. Most programming done by me does not use those 2 settings because most peoples schedules don't correlate. Some thermostats can even be set up to delete those 2 settings, and only use the sleep & wake for night setback.
Feb 11, 2014 | Hunter 44260 5/1/1 Program Digital...
My Janittol HPT 18-60 has posts marked Y, G, R, O, W2, E and C. The Hunter thermostat 44260 has fewer post connections G, RC-RH (with Jumper), Y/O, W/B, and Y1. What is the conversion and which wires are...
If your current thermostat is using all of the posts, you most likely have a dual stage heat pump system. A dual-stage heat pump system utilizes electric strip heat as backup heat for use during defrost cycles and to supplement the heat during outdoor temperatures below 30 degrees.
Here is an excerpt from the installation guide of the Hunter 44260 t-stat as well as a link to the guide itself.
"This thermostat is not designed for multi-stage heat
pump systems"
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42711.pdf?n=6278
Feb 25, 2010 | Heating & Cooling
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
What is the term. y1 used for 0n the hunter thermostat
y is the condensing unit outside trace the wire b is used as a common in most cases but it all depends on what the installer decided to use. Be careful not to burn up your transformer or circuit board.
Aug 11, 2009 | Heating & Cooling
Hunter 44260 thermostat
Here is a link to directions on setting up the programming modes on your t-stat. Follow them and you should be fine. Good Luck
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Nov 30, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
252 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
