Question about Dell A215 Computer Speakers
Help with opening them
Does anyone know where are the screws of this speakers? i found one right beneath the power input, but the speakers are still in one piece and i need to open them to repair a cable... thanks!
A215 has a detachable front (grey) cover. It is attached on 4 coaks (pins). Just push a flat screwdriver under it and turn slightly - the cover will go out a little. Do it around the cover - and it will be detached. You will see 6 screws (or 4 in the left speaker). You need to unscrew them all.
Posted on Aug 07, 2008
  • David Norwood
    David Norwood Sep 22, 2015
    Thank you for the answer to the front Grey Cover and inside screws.
    FYI: There is also a hole with a screw on the very bottom, under the power connector of the speaker in the back.
  • 781 Answers
Sometimes screw are under labels stickers etc
Posted on Jul 24, 2008
  • David
    David Jul 24, 2008
    they also have clip type fittings on the joins
How to open panasonic sc-hc3
Model HC30DB dead; fuse in plug ok. My iPhone was docked so I had to open the door. The speaker covers do pop off, just persevere. Two screws in the CD bay; to open the door I found a small gap under the door and using a small screwdriver I could gently move a whitish cog in either direction and simultaneously applying a bit of pressure to the door, it released. Once inside, I found a glass fuse within the power supply casing, and the filament inside was melted. Now to source a new one.
Jan 18, 2012 | Panasonic SC-HC3 Mini Stereo Audio System...
Ok..... I have some Wharfedale Modus 8s. My question is, is that the base speaker is crackling a bit. typically when you don't have enough power the tweeters will clip first and go out. perhaps i did...
Dunno how old they are, but I just had an 11-year old pair of woofers re-edged because the foam surround and the adhesive had deteriorated. Upon close inspection the foam surround was noticeably pulled away from the cone in a few spots. Unfortunately, if there is an age-related issue with materials beneath the surface that you can't see, you'd have to pull the driver to check it out.
It wasn't until I turned my bass up loud that anything sounded wrong, which precipitated looking for the culprit (quickly found).
Nov 08, 2010 | Wharfedale Modus One-Six Speaker
Does anyone know how to remove the plastic foot rails on a nordictrack A2350 treadmill?
you must remove the screws allens including those found beneath the label. be careful when lifting
Sep 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
Apr 15, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Companion 3 were plugged to 220v instead of 110v. What can i do??
alot of speakers have some kind of glue or epoxy, so if the screws vibrate out the glue will hold it together. you may have to pry the panel off. hope this helps! good-luck, glen.
Aug 01, 2008 | Bose Companion 3 Computer Speakers
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Only one speaker works.
It took me a while, but I figured it out and successfully repaired it. Probably not worth the 3 hours I put into repairing a $19 speaker system, but am I ever proud I repaired the set and its not in some landfill in China
Here's what to do:
1. Remove the screw at the lower back of Right Speaker (the one with the volume knob that is broken and without sound). You will need a long thin screwdriver - and this screw is very, very hard to remove.
2. Carefully remove the fabric speaker faceplate on the front side by pulling at the edges carefully,
3. Under the faceplate there are 6 screws. Remove the lower two and upper two (securing the top part of speakers)
4. You should be able to separate the back and front halfs of the speaker enclosure now.
5. Desolder the speaker stereo audio input cable from the printed circuit board and replace by soldering in a replacement cable. I scavenged a replacement cable by cutting the cable for a set of stereo headsets I got for free on an airline flight. There are three wire, white (left channel), yellow (right channel), and black (ground), You need to remove and resolder all three wires.
6. The problem is that the existing stereo input cable develops an open circuit somewhere in the cable for the right channel. All you need to do is take ou the old cable and solder in a new replacement cable.
7. Reassemble and your good to go!!!!
Jun 18, 2007 | Dell A215 Computer Speakers
Dell A215 Computer Speakers Logo
734 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
