Gateway MT6705 PC Notebook
Installation disk
posted by jesus16 on Jul 23, 2008
to repair but black screen with arrow comes up after it starts up
Comment posted on Jul 23, 2008
yes i can
well it got to the blue screen where the little box which tells you to repair would come up but the box has not appeared
ok now its working just very slowly will i still have to replace thehd?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Pyrhyc
Rank:Guru Guru
Rating: 87%, 1120 votes
Is the arrow the curser and can you move it with the touch pad?
O.k. This is going to be a failed hard drive. What's happening is that one or more of the many sectors in the hard drive, that the operating system is written to, is corrupt or unreadable, so, the system reads to that point and past that point but can't put the two together, therefore it won't boot or run properly. It's kind of like reading a three hundred page book that has hundred or so pages ripped out of the middle, you need all of them to put the story together. Unfortunately, you will have to replace the hard drive.
Possibly, if it's working but running very slowly, it could still be a bad sector that it's having a hard time reading through, or it could also be a bad memory chip. Try removing the memory and starting with one chip in, then change them. If you see an improvement in the start up or it gets worse, then one of the chips has failed or is failing and will need replaced. If you find a failed chip, don't put it back n the machine. If the memory checks good, then it's still in the hard drive. It may run for a while, but eventually it will go out completely. I suggest backing up any data to disc that you want to save while it's up and running.
Rating Locked! (?) jesus16 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on installation disk:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
Hi, My friend is asking me to help her with this problem:...
How do I open up the laptop to get access to the pin to...
i had my mt6705 changed from vista to xp.after few months...
wireless network adapter cannot find any wireless networks
Battery charger sometimes doesn't work. Internet restarts...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
