Question about Sony Cyber-Shot DSC-P200 Digital Camera
Water damage/lens stuck
My camera got wet and I managed to dry it out and also recharge the battery successfully. The camera will turn on, but the lens doesn't open and the only thing showing on the screen is USB Mode; I can access a folder, but can't get into it. What is the trick here since the memory and battery are still in tact, just can't do anything? Help!
Mine did the same thing last night. I was cleaning mine with a cotton swap and alcohol, in the usb port.
After I got back home, I hooked it up to the usb cable and turned it on. Computer detected the camera as normal. Turned it off and unplugged it. Turned it back on and all was normal.
Communicating with the computer un-confused the camera.
Posted on Jan 11, 2009
Fuji finepix s1500 water splash damage. my fujifilm finepix s1500 had a slight water splash from a wave on a beach. Now it wont start up/work. It was dried immediately, and i underdstand that salt water...
It might be the salt water has got into its main chip circuit board or may be its blocking the power switch circuit. And there is a chance of the lens motor being stuck by it. You can also try another battery or recharge your battery and try it again. If you have no other choice that throwing it and buying another one then try washing it with normal water, let it dry then try again.
Oct 13, 2011 | FUJIFILM Finepix S1500fd Digital Camera
CAMERA WILL NOT TURN ON--JUST BEEPS
hi,
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
For the lens problem you can try the below method:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Goodluck,
Please don't forget to rate me as fixya..
Feb 02, 2008 | Samsung Digimax S630 Digital Camera
I spilled part of a bottle of water in my pocketbook. The battery recharged fine, but the camera is not getting power and is stuck in the "on" position, with the lens out. I haven't tried...
IMMIDIATELY put the camera ( with all cards/batteries out, slots open) in a bowl of rice for at least two weeks. I did this with a badly water damaged iPod Touch , and it is now in perfect functioning order.
More detail:
http://www.wikihow.com/Dry-a-Digital-Camera-(Bowl-Method)
You can also buy a product to help you:
Hope this helps! PS: don't wait until it soaks into the electronics, it can be fatal to your camera
Be Sure To Rate macapplezoo 100% Or Whatever You Think i Deserve!
May 31, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Pentax Optio W90 Digital Camera
Camera will not turn on
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. Another reason is memory card. Remove the card & try. If your card is virus infected the also the couse of this reason. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Apr 04, 2010 | Kodak EasyShare M1033 Digital Camera
I got my camera wet. After drying it as thoroughly
That's not the way to dry out a camera. The electronics need at least a week to dry out. You should have buried it in a bowl of dry rice and left it alone. Just turning it on while moisture is inside will short out the circuits.
Mar 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony t90 got wet with a water splash during swimming now i cant take pics and there's "E:62:02" Constantly flashing.can u pls help me?
Open the battery compartment and remove the batterys and the memory card. Completly dry the camera as best you can without further damaging it. Let it set open up like this for about 5 to 7 days. Recharge the battery and reinsert the battery and memory card. If you have to reinsert the battery to recharge the battery, do so. If it still doesn't work, contact the factory for a repair estimate.
Nov 13, 2009 | Sony Cyber-shot DSC-T90 Digital Camera
Water problem with canon digital camera
u must let it dry if you did not remove the battery when the unit got wet then its a goner water damage sends electronics to there grave fast! if battery is left in the gold and copper traces start to corode ! and in minutes not days!
Aug 29, 2009 | Canon PowerShot A95 Digital Camera
I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
My Panasonic Lumix DMC-TZ3 was soaked in water. It isn't working, will it work when it drys out?
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Aug 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
189 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
