Question about Nokia E61 Smartphone
Nokia E61, Flashing Screem
My Nokia E61 is flashing the screen, i can do everything, but my screen is always flashing to a white screen, any ideas??
  • 2 more comments
  • nranpura Aug 03, 2008
    My nokia-e-61 randomly brings "white screen", i can receive-send phone/messages, but screen is white, so can not see it..!!
    I am very frusted with Nokia's support on this. One time, they changed display IC, but it remained, second time, they replaced display connector, but it is still same. Anyone has any idea ? please help.
    Nilesh
  • farhanesar Aug 11, 2008
    My phone is working fine. Making calls, sending sms etc is fine but i can not see any thing on my screen as its compelety white. what to do
  • eman66 Sep 09, 2008
    Hello, I'm having the same problem.The phone is working but the screen is blank.The phone never fell to the ground, it was on my desk and, at one time, the screen became blank.
  • mwallacegree Dec 09, 2008
    In the morning my E61i worked just fine. Came to work, and noticed the 'white screen'. Figured out the phone still works but cannot see anything but white. To be honest, I dropped it a couple days ago, so if this has something to do with the current white screen it was a delayed reaction.
    I am reminded how dependent I am on my phone. Completely lost without it!
  • 3 Answers
Let me guess ... you dropped the phone at least once recently?
Well, I did the same, and the first three times I got it working by smaking it face-up on the table (literally!). However, this morning was the last straw, and I could not get it working again.
However, I now know this is an easily repaired problem that someone with very basic skills and tools can tackle. With the earlier crude remedy I suspected a loose contact, and this was confirmed by squeezing the phone just right between the power light and the speaker I got the backlighting to work. To fix it, the steps are:
- Remove battery cover
- Remove battery
- Start disassembly by removing top rear shell (the bit with the lens cover) by gently prising with a small screw driver. There are five catches - one middle left, one middle right right, one center bottom, two at the top +/- 1/2" from the edges. Gently remove the in the same direction as you would the battery.
- Remove front shell by undoing 4 screws now visible on the rear of the phone, one at each corner. Itis a funny torque screw, but I used a small flat and it worked OK
- Turn the phone face up. Right at the top and about 1" from the left there is a red screen connector (you'll see the copper of the screen's strip cable terminating there). Gently press down on this connector to reconnect, and Hey Presto!
- While you're about it, remove all the dust and muck in the phone.
- Reverse the steps for re-assembly
If you do not feel up to it, take the phone to an agent or repair shop with these instructions. It is a 5 minute job and they should charge accordingly!
Francois
Posted on Nov 12, 2008
JUST TODAY I DISCOVER THAH MY PHONE CAN SHOW LIGHT ON THE SCREEN AND SOMETIME THE KEYBOARD DOSE NOT WORK
Posted on Dec 12, 2008
Tip
Nokia Dead Phone White Screen
<span><b>DEAD PHONE FLASHING -- REVIVE YOUR PHONE! (Tutorial)</b></span> <span><b><br /></b></span> <span><b>NOTE: </b><br /> <ul> <li>100% Working on WIN XP.<img src="thumbsup.gif" /></li> <li>Tried it on WIN7, ONLY 2 out of 5 success rate. <img src="dontknow.gif" /></li> <li>You will ONLY need internet for downloading the files. After installing all files, NO NEED FOR ACTIVE INTERNET CONNECTION while doing the flashing.</li></ul><u><b><br />YOU'LL NEED:</b></u> <b><br /><br />1. Compatibe Nokia USB cable.<br /><br />2. Phoenix Software</b><b><br /><br /></b><b>3. LATEST Firmware from Blue Nokia.<br /><br /></b><b>4. Your DEAD NOKIA CELLPHONE.</b><br /><br /><b><u>DEAD PHONE MEANS</u></b><br /> <ul> <li><b>When you turn on your cellphone you only have <u>White Screen</u> but it WILL NOT CONTINUE TO TURN ON. <br /></b></li> <li><b>VIBRATE ONLY but no WHITE SCREEN - this is a different case. You may have hardware problem. You can still try this tutorial since you have nothing to lose. <br /></b></li></ul><br /><u><b>INSTRUCTIONS:<br /><br /></b></u><b>1.</b> Turn off cp -&gt; remove battery -&gt; look where your cp was manufactured -&gt; note the RM version & the 7 digit product code <br /><i>(Ex. Made in China, RM-346, Product code - 0576672)</i></span> <span><b>2.</b><b> <u>D</u></b><b><u>ownload & Install</u> the compatible firmware</b> version for your cp. --&gt; go here </span><a href="http://www.blue-nokia.com/">http://www.blue-nokia.com/</a> <span>-&gt; On Blue Nokia website (upper right screen) <b>choose phonetype</b></span><i>(Ex. select <b>E52</b>)</i> <ul> <li><b>Choose APAC</b> for cellphones made in Asia. <b>If APAC is not available, you can use SEAP/EMEA.</b></li></ul> <ul> <li><b>Choose EMEA/MEA</b> if it was made in Europe, the Middle East and Africa<b>.</b></li></ul><br /><b>3. Download and Install PHOENIX.</b> <b>--&gt; </b><a href="http://www.mediafire.com/?yi3wo0ymx0m#1">http://www.mediafire.com/?yi3wo0ymx0m#1</a> <img src="vhin100889_31.jpg" /><br /> <span><b><u>NOTE:</u></b> <i>If any ERROR APPEARS ON INSTALLATION -&gt; JUST CLICK <u><b>CONTINUE ANYWAY.</b></u></i></span> <span><i><u><b><br /></b></u></i></span> <img src="vhin100889_32.jpg" /><br /> <span><i><u><b>Read and follow my instruction step for flashing dead phones </b></u></i></span> <span><i><u><b><img src="vhin100889_33.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_34.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_35.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_36.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_37.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_38.jpg" /><br /></b></u></i></span> <span><i><u><b><img src="vhin100889_39.jpg" /><br /></b></u></i></span> <span><b>AFTER STEP 12. YOUR PHONE WILL START TO UNDERGO FLASHING. <br /><br /></b>AFTER SUCCESSFULLY FLASHING.<b> <u>IT WILL RESTART ON ITS OWN. </u><br /><br />if not... JUST RESTART IT MANUALLY ---&gt; THAT'S IT!!</b></span>
on Jul 14, 2011 | Cell Phones
Hello guys ... my phone's (5220) screen has gone White ... !! i have absolutely no idea what the problem is ! i took out the battery and put it back again .. but when i turn it on ..after the nokia logo...
hi , it have the software problem. so you need to reinstall or flash the mobile. you can use service softwares like phoenix . If you have not sufficient idea about how to flashing , then it is better u to go the nearest nokia service centre.
Feb 08, 2011 | Nokia 5220 XpressMusic Cellular Phone
Blank Screent with flashing pink bands
hitachi bs always have bad voltage regulator ic's like an STR6301,Need to replace
May 05, 2010 | Hitachi 51F500 51" Rear Projection...
N72 screen flashes white
the problem on it is the crystal iC of the Display, replace it
Apr 10, 2009 | Nokia N72 Cellular Phone
Screen is always white when it comes on cant get it to work
You need to reflash the fw. It takes a little bit of work. look for dead phone flashing
Oct 28, 2008 | Nokia 6133 Cellular Phone
Flashing Screen/Not starting up
you need to format your cellphone maybe the operating program was corrupt
Sep 07, 2008 | Nokia 6600
Nokia E61 Boot Failure
I had this problem once. My problem was due to a file (currupted) in my memory card. I found this out by restarting the phone without the memory card. once the phone was up and running, i looked for the damn file and deleted it...
Mar 26, 2008 | Nokia E61 Smartphone
Nokia E61 Smartphone Logo
663 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
