Unable to line up the color on the tv - Televison & Video
  • 8,617 Answers
You need new convergence ICs. Please respond to this post with your model number and I will post the correct IC numbers for your model TV.
Posted on Jul 24, 2008
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How do you get it out of 3d what do I adjust, its not a 3d tv
This is an color projector alignment issue. Many projection TVs have a menu item in the video or picture setup that will produce a grid overlay on a black screen of Red, Green and Blue. You use the <, >, up & down buttons on the remote or the TV to move each color (one at a time) directly on top of each other and maintain straight up and down / left and right lines. Once you do this, the picture will be in focus and there will be no more colored "3D-like" ghosting. If you are unable to move the colors far enough, there may be an issue with certain integrated circuits inside the TV that can be challenging to remove and replace. More make and model number for your TV would be required however.
May 21, 2014 | Televison & Video
We won a new sony tv, after setting it up, i was adjusting the color,when tv wentBLACK with white lines running thru it,unable to get picture again.thanks chuck
Tries unplug,replug the tv back like an hour.Now,the tv is resetting itself back to factory setting.The tv should work again.If not,the tv Tuner signal board have problems.Tv is less than a year old wright?Call Sony Corp. for a warrenty repair.
Oct 17, 2010 | Sony Televison & Video
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
My Hitachi Ultrascan is about 8 or 9 years old and it has been the best TV until lately the colors are not lining up. There is a blue arch at the bottom of the screen and over the past few weeks I was able...
Very common in DLP tv u lucky is last it this long.Usally 2-3 years the Convergence ICS are dying will be dead and all it supporting resistors is dead .The convergence is dead,must know how to solders,repalaced Convergence ICs all it resistors.Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u 300 for parts and labors.
Jan 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Vertical colored lines scrolling across the screen. unable to turn on or off
Call the repair guy. If you can't turn the unit off, there are problems that you probably can't repair yourself.
Nov 19, 2009 | Astar LTV-19BG TV
My vizio hdtv color is off and i need help adjusting it
We had the same problem (for about a week) and finallly realized that the kids had played with the cords in the back of the TV and one connection was loose.
Mar 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Televison & Video Logo
Top Televison & Video Experts
