Ac runs- blower blows- etc new a coil installed - same problem- 82 degrees in house - a coil 50 degrees- vents 73 degrees.
Inner sides of coils blocked by debries
Posted on Jul 23, 2008
Heat TEMP and blower problem.
Your blend doors are not working properly. There is small electric motors that move them. Shouldn't be really expensive to have fixed.
Jun 01, 2017 | 2000 Chrysler LHS
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
Olds aurora 95 ac -- freon good. starts good in am. runs great. ac blows ice cold 60 degrees ( using a lazer temp gauge) out side temp 77 degrees -- ran for 2 hrs. ice cold. Then outside temp over 85...
About the only thing that it could be is a dirty coil,or some one over charge the system, I have seen just a layer of dust cause the compressor to cycle off to its thermal over load. Clean the coil.
Jul 08, 2011 | Heating & Cooling
I recently purchased a used ac for my rv. it has two and one had gone out. the air coming out of the new one only gets down to 60 degrees while the air out of my old one is 50 degrees. they are both the...
No it means you 50 degree one is working better than perfect. Clean the one that is only getting down to 60 degrees but remember if a unit is dropping the air temp by 20 degrees its working fine. You ck this by cking the air at the intake where the filter is say temp is 80 degrees and then take a reading at a discharge vent where the cold air comes out if its 60 you have a 20 degree drop and that is considered good. If the unit was low on freon the unit will freeze up (ice will form on the inside coil).
Aug 10, 2010 | Dometic Rooftop RV Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Ac leak at coil durango 1998 how much for repair is typical
I had a 1999 Dodge Durango with the 4.7L V8 and actually sued Chrysler/Dodge and the 3 dealerships under the Magnuson-Fergey(spelling?) act for breach of warranty repair. I had spent over $4500 over the course of 3 summers attempting to resolve the problem. We replaced the pressure release valve, condenser, coil, lines, blower etc. I was convinced it was a lemon or the aftermarket TV had damaged the roof AC.
It turned out to be the pressure release valve (#2) had broken at installation. Ironically this was the very first part replaced under warranty, and the replacement unit was defective or improperly installed.
The problem really only surfaced when it was over 95 degrees F. It would cool it down some, but not the 47 degrees according to specs at the vent.
After Town Motors in Exton PA finally resolved it, I ran it for 3 more years before selling it to little brother. He still runs the wheels off it, an otherwise good truck.
I still miss that V8...ahhh memories.
Jul 11, 2009 | 1998 Dodge Durango
Air Handler Blower
if you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
The thermostat is set at 73... the air conditioner is running and cold air is blowing but the house is currently 82 degrees. I've checked the unit outside and there is no icing. I don't know what to do.
check to see supply air should be around 58F. 20* difference form supply air to return air if 58F my guess unit under sized air filter clean? when was the last time you had the unit tuned up?
Jun 20, 2009 | Heating & Cooling
Blower motor location and installation on 73 ford gran torino
It's less than foot from the heater core. I would guess that either the damper doors are not on correctly or the vent hoses are not hooked up. Can you hear the blower motor running? Maybe they didn't hook the motor back up when they replaced the heater core. It takes a ground and a hot wire.I can't remember where it's at but it may be part of the same unit. Did you check the fuse?
Jan 04, 2009 | Ford Thunderbird Cars & Trucks
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
