FixYa.com
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Singer sewing machine
posted by jpic8844 on Jul 23, 2008
I have a Touch and Sew Model #648 and the feed dog broke. I purchased a new one but can seem to get the two little screws out. Is there something I can do to get them out?
Comment by jpic8844, posted on Jul 24, 2008
too late of a reply, that's exactly what I did thanx
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
jpic8844
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I sprayed the little screws with liquid wrench and got the end of a small screwdriver tip and turned it with a plyers. you see the screws are right under the needle and the clearance is very tight. thanks for asking
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
RickE1
Rank:Guru Guru
Rating: 92%, 46 votes
First try leaving a few drops of penetrant (PB Blaster or WD-40)on each screw letting it soak in overnight. Then using as short of a screwdriver ,with the best fit to the screw, as you can fit under there put it in the screw head, push down hard and turn the screwdriver with a pliers. This should break them loose.
This Problem Also Relates To: Kenmore 11206 / 11306 / 11506 / 11606 Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Kenmore 11101 Mechanical Sewing Machine Kenmore 19606 Computerized Sewing Machine Kenmore 744-08BH Mechanical Sewing Machine Kenmore 15202 Mechanical Sewing Machine Kenmore 15212 Mechanical Sewing Machine
Can you Help with these Sewing Machines problems?
Euro-Pro 7500XH Mechanical Sewing Machine
NEED USER MANUAL FOR 7500
need user manual for 7500 model Answer This...
Singer 7462 Mechanical Sewing Machine
7462 problem
I was winding a bobbin on my... Answer This...
Sewing Machines
tiptronic needle bar broken
needle bar for my tiptronic is... Answer This...
Husqvarna Viking 1
I get a " Check
I get a " Check upper... Answer This...
Husqvarna Viking 1
husqvarna sewing machine
Hi, i have been given a... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
