Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire Model number frs26znh defrost not working?
My refrigerator froze up the other night, so I thawed it out and have been running it for a day and a half now. The evaporator coil is staying white and seems to be slowly building ice, but is holding temp. I was wondering where to start with the defrost system and how to accsess it. Please help..
Thanks, Bill
  • mailliw130 Jul 25, 2008
    Thank you, timer is definitely bad, I ordered both the timer and the thermostat as you suggested.. thanks again...
  • 725 Answers
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Jul 25, 2008
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Frigidaire Model number frs26znh defrost not working?
it is on the top of the inside of the refrigerator and if it is not you may have to take off the knob for the thermostat and turn the red knob that is sitting in the hole.
Posted on Dec 23, 2008
Why isn't my frigidaire ice maker working?
Hello Lynn, thank you for your post!
I understand that your Frigidaire refrigerator is not making ice and items inside of the freezer are thawing out. This could be an issue with your control panel or sealed system, is there anything being displaying on the front of your refrigerator? May I also have your model number? You can locate your serial tag (which lists your model number) on the right hand wall of the fresh food side. With that information I would be able to assist you further. -Matt
Apr 19, 2016 | Frigidaire Refrigerators
Freezer coil, inside freezer compartment continues to freeze to a solid block of ice. Apparently the auto defrost isn't working. I can manually shut it down, thaw it and restart. It works fine for...
Your defrost circuit is made up of a defrost heater, defrost thermostat and a defrost timer (generally, but will depend on make and model). They are relatively straight forward to troubleshoot and replace, and not that expensive.
Suggest you go to www.searspartdirect.com and plug in the model number of your frigerator and look up the parts you need to get an idea of how much they are. NOTE: Sears isn't the cheapest place to buy the parts, but they use the real part number for further research.
Sep 10, 2011 | Frigidaire Refrigerators
I have a Frigidaire Model FRT18s6aws year model 06. It will thaw an d refreeze food and ice on and off. When it thaws it seems the fan is working fine and is triing to get cold and the next day everything...
When your unit thaws - do you hear the compressor kicking on at the start of a cycle? If not, maybe the compressor relay it hanging up somehow. Or the compessor capacitor is malfunctioning. It is NOT a compressor problem though.
If you are capable of getting to the defrost heater circuit, you should check the defrost thermostat and timer (if there is not ice build up behind the panel. If the defrost circuit is active too long it could cause that condition - but you defrost heater is not the problem unless there is an ice build up.
Jun 12, 2011 | Frigidaire FRT18S6AW Top Freezer...
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor. i have looked for a stopped up drain plug or hole with no success. please help. john
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Frigidaire Refrigerators
Every time my Frigidaire Model number frs26znh defrosts, water runs out of fridge door. of course, the pan in bottom of fridge is full of ice. water has not been connected for 6 weeks
Your Defrost drain Plug is clogged or kinked.
Check the tube from the freezer to the fridge, make sure it's connected, then pull out your drawers in the bottom of the fridge and clear your drain hole..
Mar 11, 2010 | Refrigerators
Frt21lr7ds3 freezes then thaws out runs for 1 hour then shuts of for one hour which thaws out every thing and leaves water on floor
The most likely cuase of this problem is that your defrost timer is not owrking properly. It seems that it is cycling too frequently and causing all kinds of problems for you.
You can purchse a defrost timer online easily by doing a search for "appliance parts" these sites will want the model number of your unit and then will give you a parts breakdown for it. Check a number of different sites as the prices can vary greatly.
Hopefully this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 23, 2009 | Frigidaire FRT21P5A Top Freezer...
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
Sep 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerator not cooling below 55 degrees. Freezer works fine. Coils under refrigerator are clean and compressor is running.
Check the defrost timer, it may be out, if the coils in you freezer are all froze over with ice it may stop your fan from circulating the cool air to the frig side, this is cause by the defrost time not working. It will need to be replaced. You will need the model number and to thaw the coils with a heater or to unplug the frig while it thaws. If this is your problem call First
Source and provide with model number and ask for a defrost heater. Replace per instructions.
Jul 05, 2009 | Refrigerators
Dec 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
719 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
