Question about Akai LCT4216 42 in. LCD Television
No picture and sound
When whatching the LCT the power went for a second or two and then when i tried to restart the tv the power light come on but not the pic or sound.
What could be the problem exactly....i keep the tv on a surge protector.
  • jokim143 Sep 11, 2008
    red lighit just flashes
    Problem Solver:
  • 53 Answers
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Posted on Aug 09, 2008
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
LCT 2662 after caps replaced I loose backlight.
make sure the caps you installed are the exact replacements. Changing voltage capacity or timing will cause the circuit to fail.
Feb 21, 2009 | Akai LCT2662 Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
My akai lct 2070 screen has two issues one is that about a month ago the screen went black only viewable with a light next to it and now when the tv is turned on it stays on for about 30 seconds before it...
Inverter
power suply
CCFL assembly
One of these boards are causing this problem, we have them in stock if you need them. the tv is programmed to shut down if all circuits are not functioning properly.
Dec 25, 2008 | Akai LCT2060 Television
Power Surge?
Sound? audio from station.. or noise this set is going into shutdown. the processor is seeing a problem with its safety cuircits and shutdown the set it will try to restart the set 3 times and then lock it down. it can be many things. the processor has an error log.. technician can get in and read codes.
Nov 16, 2007 | RCA D52W19 52" Rear Projection Television
Akai LCT4216 42 in. LCD Television Logo
140 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
