Back to:
Tags:
Nokia 6288 Cellular Phone
Unable to transfer contacts from nokia 6288 to...
posted by ytwinsah on Jul 23, 2008
I need your kind support in resolving my issue as below:
Contacts on my nokia 6288 reached 500 names, and i am unable to add new names. I've tried to transfer those names to my SD-memory but it seems this option is not available. If available, pls tell me how,
Also, when i sync., no contacts get copied from phone to pc ?
Thank you & regards,
Fuad
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2008
Not Rated (0)
nokurajesh
Rank:Guru Guru
Rating: 85%, 31 votes
open menu...select contacts...goto settings....press select you can see memory in use..press select again you can see an option phone and sim press select...
so now you can add many more contacts...
Try this please.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on unable to transfer contacts from nokia 6288 to labtop:
I don't want to Accept this solution
Can you Help with these Cellular Phones problems?
hi please could you send me an unlocking code nokia 6288...
I forgot my security code using Nokia 1100... i want to...
Hi dilipbagdi Just wondering if you could help me with a...
imei: 355547014850383 please help me unlock my phone I'm...
plz give me 6085 unlock code
Loading problems.
Repair Service
Find Cellular Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
