Question about Brookstone Pure-Ion (506840) Air Purifier
Help! I have the Brookstone Pure-ion. I recently washed and cleaned the filters. After drying and reinserting the filters into the unit I started the machine. During the intial start sequence the CLEAN FILTER light illuminates. The unit operates normally for a few minutes, then a buzzer goes off and the whole panel lights up. The machine doesn't shut off, the fan continues to run. I have to unplug it to shut down.
  • tskogg Jul 24, 2008
    Tried that. No better.
    Master:
  • 382 Answers
Hopefully the inner circuit board is messed which needs a service for getting it back to condition..Call up the service person from the company,that will solve your problem..Thank you!..
Regards!!!!...
Posted on Jul 24, 2008
    Genius:
  • 1,689 Answers
The filter case actually has a part that triggers the clean filter light to turn on when it is dirty, when you clean the filter and placed it back, there is a possibility that the actual trigger may have been touched and was stuck, that is the reason why the unit is not powering off. the pwoer switch will not initiate if another switch in the unit is triggered. best simple thing to do is to remove the filter, then carefully place them back as the manual illustrates.
good luck
-VooDooMoX
Posted on Jul 23, 2008
  • marlon john madrid
    marlon john madrid Jul 25, 2008
    in addition to that, try to check the clips of the filter case and see if you will be able to locate a trigger, it could be stuck nudged in. be very careful not to touch any circuit board.
    Master:
  • 555 Answers
Try leaving it unplugged for a while to reset it.
2 Suggested Answers
SOURCE: I get the Buzzer with an illuminated panel
Send me an email at titi113@yahoo.com
Posted on Mar 25, 2010
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-Ion® Pro - Brookstone
www.brookstone.com/webassets/pdf/630285p_manual.pdf
BrookstonePure-Ion® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Aug 30, 2015 | Brookstone Pure-Ion UV Air Purifier
Where can I but the charcoal filters for my Pure-Ion air purifier?
If you go to this website, you will see that this model has a washable filter: http://www.brookstone.com/sl/product/65099-pure-ion-pro-air-cleaner.html
If you still have the literature that came with the purifier, contact their support number if your unit has a charcoal filter.
Oct 25, 2010 | Brookstone Pure-Ion (506840) Air Purifier
My sister gave me her Brookstone Pure ion Air purifier....The "clean filter" light flashes red....I wiped the filter with a damp cloth...so think it is clean...?....Is this how to clean it? ....and how do...
Wiping it off won't clean the filter. I submerse mine in hot soapy water ( oxiclean w/any favorite multipurpose liquid cleaner.Let it air dry completely before placing it back in unit.I have tried the dishwasher method and it didn't clean it.I also thoroughly wash all crevices of the unit.If red light doesn't go off, reclean the filter(s). It has all ways worked for me.
Sep 23, 2010 | Brookstone Pure-Ion UV Air Purifier
How remove and clean filters from Brookstone pure ion uv air purifier?
how to remove and clean filters for the Pureion UV air purifier?
May 21, 2010 | Brookstone Pure-Ion UV Air Purifier
Cleaning tips for my Brookstone Pure Ion
I have Bridge Stone Ionic Air Cleaner and I cant figure out how to take it a part to clean the filter. It's a few years old, used very little and I don't have a manual. Can anyone help. thanks
Nov 06, 2009 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-Ion  (506840) Air Purifier Logo
282 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
