Samsung le32n73bd lcd tv has blue flashing light and wont turn on, after searching the net this seems to be a common problem. Any advise
Mine has justy done the same, flashing blue light and wont turn on!!
Its only 2-3 years old.
Anyone any further comments, hopefully thisd is a quick fix.
Posted on Jan 19, 2010
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
I'm having trouble with my Samsung LED tv I am getting audio but no video. I See a blue screen then eventually gets darker. Any ideas what the problem may be?
Hi Will,
This is common problem with many samsung LED TVs. This is related to the back lights in the LCD panel. If you ask Samsung they will advise for the panel replacement. If you can find someone who is expert at handling this kind of sets, the panel can be repaired also. Good luck.
Mar 23, 2015 | Samsung UN60EH6050 60 LED-LCD 1080p HDTV
Won't turn on
The most common thing to fail on modern TVs is the power board. I would take the TV apart and check the internal power board and the capacitors on it, if any appear to bulge in anyway try replacing them.
Mar 20, 2014 | Samsung LN-S4696D 46 in. HDTV LCD...
Samsung television wont turn on
there is a defect in your tv.there is parts on it shorted consult your samsung service center to fix your problem
Jun 19, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Monitor will not come on, blue light just
Check for leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 02, 2010 | Samsung 204T 20" LCD Monitor
I can't get picture on my TV. It essentially won't turn on.
Look for caps and see my pictures to see what bad caps look like, you may ahve dead inverter board.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
SAMSUNG TV
your tv inverter is bad
Aug 29, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
531 people viewed this question
Top Televison & Video Experts
