Question about Haier Dishwashers
Haier hdp18pa turn on three lights blink and then one beep doesn't turn on
    Genius:
  • 1,226 Answers
some of this kind also have problem in the circuit which preventing the unit to work on. try also cleaning the circuit board and if not then you have to replace it.
melnavz
Posted on Jul 24, 2008
    Genius:
  • 1,689 Answers
The beep means that a fuse in the unit is blown and needs replacement but the blinking light may mean that you will have to reset the circuit braker.
refer to the manual if in case, almost the same technology as your washer.
haier dishwashers
good luck
Posted on Jul 23, 2008
    Master:
  • 555 Answers
Have you tried resetting the unit?
Need operators manual for a haier dishwasher hdp18pa
www.specsserver.com/CACHE/FRWDAJEQUXIO.PDF Full downloadable manuel
Sep 24, 2011 | Haier HDP18PA Stainless Steel...
Water is splashing back at me when I hook up the Haier HDP18PA shy?
1)If cycles not complete before opens(it will splash)
2)check any block in rinse arm.
Jan 08, 2010 | Haier HDP18PA Stainless Steel...
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Haier HDP18PA
Not sure of the background on your fault, but this may help:
I have an HDW202. I accidentally opened the door while it was running - a no-no, but there is no lock preventing opening the door while it is running - not idiot-proof at all, disappointing, really. Anyway, closed the door, the washer kept running, then water started to leak out the front door. I quickly turned it off, mopped up the water, and turned it back on. It pumped out the remaining water visible in the bottom, then started flashing lights and doing 10 beeps in a row, pausing for a minute, 10 beeps in a row again, etc. - it was stuck in this cycle. I tilted the unit forward, backwards, and side to side, while turning it on and off periodically to check for results. More water came out of the unit, and it started to behave normally while tilted, but not level. Eventually, after more tilting, it returned to normal behaviour when level. It seems it did not pump all of the water out initially, and this was causing it to malfunction until all of the residual water inside had drained onto the floor from tilting the unit.
Jan 25, 2009 | Haier HDP18PA Stainless Steel...
My dishwasher keeps beeping at me and the first four lights on the panel are flashing, I have a Baumatic BW07.
I tilted mine backwards with it running and beeping and it stopped beeping shortly...It made a mess on the floor of course but I put it down and lights were still flashing but no more beeping. Thought I would try tipping it forward while it was running and the lights went off and the beeping never started again. Its working fine now??
May 18, 2008 | Haier HDP18PA Stainless Steel...
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
Haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Jun 09, 2007 | Haier HDP18PA Stainless Steel...
Haier sdw4a
hi cant help more then this: try the manual in the end of the page see if it helps http://www.haier.com/servicesupport/manualMore.asp if not contact the firm http://contact.haier.com/engdefault.asp if they dont help call a tech guy he'll know whats worng good luck
Mar 28, 2006 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
415 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
