Question about Sharp R-1480 Microwave Oven
Dimentions We have a sharp r1480 and it stoppoed working the other day. We need to replace it with something that fits in the same space and would like to know if anyone has the dimentions. Since we bought this long ago I do not have the manual
  • Sharp Master
  • 9,086 Answers
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
They should be able to tell you what current model is comparable to yours.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Sharp r884. Will there be enough space for safety in my housing unit for it which is 570 MM. Wide, 315 MM high, 580 MM deep.
Dimensions (WxHxD): 52x30.9x48.8 cm - Should fit in your space, however ... this doesn't leave much room for air flow unless there are vents in the back. There must be somewhere for the hot air to go.
Jul 25, 2016 | Sharp Microwave Ovens
I have a sharp R1480. Probable trouble in control or switch. Began by needing to hit or push harder on the start button to engage the micro. After a while it didn't respond at all. I did order a control...
It may be a bad membrane keypad or a simple a door switch issue. It's rarely the control circuit board (control unit).
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
Probably the best place the order Sharp parts is Encompass here or you can call them toll-free at 866-779-5835.
Dec 31, 2010 | Sharp Microwave Ovens
I have a sharp r1480 microwave. the work lights do not turn on. the bulbs are good,and light buttons beep but no light.
listen for a click not just a beep, if it doesn't click the relay is bad on the pc board, if it clicks the trace may be blown to the relay
Jan 26, 2010 | Sharp R-1480 Microwave Oven
Sharp R1480 - door won't close
Very much so.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Dec 14, 2008 | Sharp R-1480 Microwave Oven
Sharp R1480 door won't close
Very much so.
You will need the
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Need to replace d3v-16g-3c25 for my sharp micro...where can I get it... .1 amp 124v dc
That sounds like a door switch. Which switch is it? Top, middle, bottom?
Is your model number R1480? If not, please reply back with your model number so we can help you.
The door switches in model R1480 are:
QSW-MA110WRE0 top & bottom switches
FFS-BA016/KIT middle monitor switch with fuse (kit)
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
But the best place to order Sharp parts is Tritronics.
If none of this info helps you, please reply back with your brand and model number and let me know which part you need.
Jul 29, 2008 | Sharp R-1480 Microwave Oven
Microwave won't START!!!!!!!!!!!!
It's usually a broken tab on the upper switch holder, allowing the switch to rotate just out of position.
This tab can be hard to see, since it is under the bottom edge of the switch.
While replacing the switch holder is the preferred solution, using hot glue to secure the switch to the holder is much easier and quicker. Just be sure not to let the door be slammed from now on.
We have the R1480 service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Jul 22, 2008 | Sharp R-1480 Microwave Oven
Sharp R-1480 Microwave Oven Logo
109 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
