SAMSUMG LCD TV MODEL NO.ln-t2653h a says "No signal" whether I try all TV channels, DVD. or VHS. Bought ne 3-4 months ago and worked fine until this week.
    Genius:
  • 1,689 Answers
There is a possibility that the line-in's inside the unit may have been disconnected or a pin was removed that is why the TV is showing no signal whatever media input you use, in this case, haveing the TV serviced is the best thing to do since soldering may be done.
but to get the TV to be in factory default, unplug the unit until the internal battery / capacitors loose power, may take 3 hours least, then try to power it back on pressing the reset button on the remote for 5 seconds then let the TV initiate.
good luck
-voodoomox
Posted on Jul 23, 2008
    Master:
  • 848 Answers
Just check whether the fuse is blown ...........
also check proper power supply is supplied to tv......
I just bought a Samsun Series 4+ / 440 / 450 (on the users manual lol) but when i try to hook up my DTV or PS3 using an AV cable, nothing shows up. In the Sources, it shows "AV" but when i select...
is that the av channel? if so, how do you know your getting a signal from the ps3? try hooking the ps3 up to something else to make sure you have a signal coming out of that cable (this is where you have to start) if you have another device like a DVD player, or VCR, hook that up to the AV input (or channel one as you say). if you get a picture from those devices, the problem is your ps3 not sending the signals to the tv. sorry I can't be more helpful, but that's my guess
Mar 11, 2011 | Samsung LN-T4053H 40 in. LCD Television
My Samsung LN-T2653H is having problems with power
Possible bad(bulged) capacitors on power supply board, and possible bad main board, too.
Apr 18, 2010 | Samsung LN-T2653H 26 in. LCD HDTV
We get no signal from the air antenna, cable,or games etc.
You have a bad Main bd. Have a trained Samsung tech repair the tv.
Jul 07, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Nov 08, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
Samsung LN T2653H
You can find the schematics for the tv at the following link.
http://www.eserviceinfo.com/index.php?what=search2
May 26, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
Problems playing my Phillips DVD/ VHS with my new WESTENHOUSE HDTV
I notice this was made in 2008 and I hope you have found the answer. But if you or others have not here is my answer. Are using the RCA cable from the output on the DVD Player and you have plugged it into the RCA in ports then you need to use the remote to move through the on screen menu. My INSIGNIA has a Source List menu on the remote that shows on screen. I can scope through the MENU for TV, Composite Side, S-Video Rear, S-Video Side, Composite 1, Composite 2, VCR, HDMI 1, HDMI 2, HDMI 3. That is found using either the INPUT button on the upper left on the remote or the buttons; VIDEO, COMP, HDMI, AND TV across the top of the remote. Hope this helps.
Apr 13, 2008 | Philips Televison & Video
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
