Question about Kenmore 63942 Dryer
Kenmore 66912691 i need a serives manual ,it is making a high pich nose
  • 943 Answers
Thanks for the question You need a drum repair kit it comes with 2 drum rollers an idler pulley and geta new belt and vaccumthe dryer good it will workbetter thanks for your question Theappliance doc
Posted on Sep 11, 2008
High piched squeal
Sounds like a color wheel. Bearings in color wheel make such a sound when bad.
Nov 27, 2010 | RCA R52WM24 52" HDTV Projection Television
My traxxas revo 3.3's gears are grinding, the car has slowed down
sounds like engine is running to lean. count how many times the high end needle is out. will have to retune engine before piston seizes completly up.
Jul 20, 2010 | Traxxas Rc Revo Nitro Monster Truck
98 pontiac granb am... run good tell that fuel starts making a hi pich nose. then die it starts back up. well i did now it starts but give it gas and it puts????? can you help me.....????
You should start with testing fuel pressure you may Also wont to replace your fuel filter,.If the fuel pressure test OK the high pitch noise you are talking about is it from the exhaust .if so then chances are that you have a bad catalytic converter ,if bad it may rattle if taped on ,is so what happens is the broken pieces in it turn sideways causing a restriction in the exhaust ,hope this helps you ,please let us know if we can be of any further assistance . Thank You.
Mar 30, 2010 | 1991 Pontiac Grand Am
Transmission makes loud high pich noise in park and while driving
this noise is most likely coming from the transmission pump, its a sign that something is on its way out have transmission shop look at it,cheaper to replace with used one
Jan 20, 2010 | 2001 Dodge Caravan
Hi, I have a 1994 Toyota Camry 3.0 motor. At high rev or under heavy acceleration the engine makes a high pich winning noise kind of like the cateletic converter is plugged but I had it removed and it did...
ON SOME CARS THERE IS MORE THEN ONE CATELETIC CONVERTER SOME HAVE THEM IS THE EXT MANIFOLD AND YOU WILL HAVE TO TAKE IT LOOSE FOR THE EXT SO YOU SEE INSIDE IT
Nov 16, 2009 | 1994 Toyota Camry
Phillips TV
check the horizontal output ic or the flyback transformer
Jun 08, 2009 | Televison & Video
How to eliminate high piched engine hum
switch out the belt if you allready done that make sure there is only half inch of play in the belt if that dont work grab some wd -40 spray the tensioner pully on the car if it quiets the car replace the tensioner pully make sure resavoir is full on pump too those are the quick and easy ones if that dont work then switch out the pump its two hose and 2 to 3 bolts make sure you bleed the lines too if theres air in the lines it will scwill
May 19, 2009 | 1999 Buick LeSabre
No Picture/High Piched Sound
bring it to the authorise service center man, simple. Fred-Modern Home Qatar
Jan 26, 2007 | Panasonic CT-36D11 36" TV
Televison
The high pitched sound is probably comming from the power supply, possibly due to its trying to drive voltage into a shorted component in the high voltage deflection circuits. You may be lookng at about a $250 repair. If it has been used a lot and its picture quality didn't knock your socks off, I would replace it with a HDTV set. A 37 inch LCD from Toshiba might be a good place to start and should do nicely for you.
Jan 24, 2007 | Panasonic CT-36D11 36" TV
Kenmore 63942 Dryer Logo
209 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
