Question about HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart check color cartidridge ?
I have replaced the color cartridge and it still gives me the same message?
    Problem Solver:
  • 5 Answers
I'd clean the cartridge connections on the printer, try a new cartridge and refrain from using reinked cartridges.
Posted on Sep 08, 2008
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Aug 01, 2016 | HP PSC-2410 PhotoSmart All-in-One Color...
Error message "Remove and check color cartridge"
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Mar 19, 2010 | HP PSC 2410 All-In-One InkJet Printer
I get the message "remove and check print cartridge" on my hp 2410 printer. I Replaced the black cartridge and still the same. I do not use color and have had cartridge in for a couple of years. Any way...
I don't think so. Printers usually won't print unless it can detect both cartridges. It doesn't matter whether the colour one is empty or full, as long as it can detect it you can usually still use black.
Sep 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Feb 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart printer is printing faintly and only bottom half of words in paragraphs. The color is also faint. I have replaced both the color and black cartridges. I have also run head cleand and...
Try taking out the cartridges and blot the bottom of the cartridge with paper towel wetted with warm water.Repeat several times.While the cartdigdes are out, use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridges.
Feb 01, 2009 | HP Photosmart 2410 All-In-One InkJet...
"Check color cartridge" error message
Try resetting the printer to factory defauts. Hold down the # and 6 buttons. Pull out the power cable while holding these buttons down. Keep your fingers on these buttons and put back the power cable. It should now show (full/partial reset). Follow the prompts and setup all your original features. If this fails then you might have a hardware problem.(Carriage assembly or Cartridge Holder)
GOOD LUCK
Jan 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
2410Xi printer cartridge replaced. still displaying ''remove...''
there are two cartridges in the printer did u replaced both the cartridges ,as sometimes both the cartridges r faulty.and so this message comes.
Nov 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
