Question about Konica Minolta bizhub 350 All-In-One Laser Printer
It gives the error code c-1191 and this won't let the staple function work.
  • 3 Answers
If this a black and white BH350, it appears you may have a crack in a mount for a motor in the finisher. You will need to call for service on this so the appropriate parts can be ordered and replaced. If you have a maintenance agreement, it should be painless. If you are being serviced by a dealer as opposed to a KMBS branch, make sure they are an Authorized Dealer. I hope this helps.
Posted on Aug 30, 2008
Canon it 7105 showing finisher error
Need the error code. You may be able to put it in "limited functions mode" to allow basic copy functions, but no finishing or stapling.
Jan 23, 2017 | Canon Office Equipment & Supplies
Canon Image Runner 4570 saying load staples when staples have been replaced
yes, there is in additional function then Common setting then finisher or staples you swicth to off
Mar 06, 2013 | Canon imageRUNNER 4570 Copier
Problems &Solution of Error E530 of model ir3300
for E000530-0000 error, Just go to Aditional Functions - Adjustment and Cleaning - Staple Function and OFF it.
Machine will work but finisher may not.
Thankyou
Aug 24, 2012 | Canon Office Equipment & Supplies
I tried to staple too many papers together using my Rexel Staple Wizard, now it won't work - any ideas?
open and check the clip from where the pins come out for staple. may be one or two pins are stuck in it.
Dec 15, 2011 | Tools & Hardware - Others
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
I have an rca universal remote model numberrcr350 i cant get the code for an orion tv and how to do it
I found 3 codes: 1030, 1035 and 1191.
Code 1030 for Orion TV Code 1035 for Orion TV Code 1191 for Orion TV
For other devices, try the remote code finder http://remotefinder.rca.com/default.aspx?site=rca . Try the search twice if it gives you a problem the first time. At times, the search engine has server issues. Please note that if the remote was programmed less than 6 months after the TV was released or is older than the TV, the code you need may not be part of the programming. In that case, you need a newer remote or one that is programmable (via a computer's USB port for example).
I hope this helps.
Sep 30, 2010 | RCA RCR350 Remote Control
Codes for cybertec RM-312x remote control for JVC
1515, 1516, 1646, 1717, 1733, 1743, 1827, 1829, 1832, 1031, 1064, 1065, 1073, 1075, 1081, 1095, 1099, 1112, 1114, 1164, 1166, 1191, 1205, 1264, 1268, 1313, 1332, 1333, 1414, 1456
Nov 29, 2009 | Televison & Video
Error E000532-8001 on iRC3170
532 means the staple head is not moving into posistion you might want to open the door and of the finisher and stick some folded up paper in the door interlock and see if the staple head is hitting something when it tries to move good luck
Jan 01, 2009 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
821 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
