Akai gx-646 capstan motor runs way too fast. - Audio Players & Recorders
You must replace transistor for capstan motor speed ( transistor code is 2SC2336 ). This transistor it is near power transformer.
Posted on May 05, 2009
My akia gx 625 does not turn at required speed. What needs to be completed to resolve issue
The last time I had one of those and I do not work on them too often on purpose is the capstan shaft was glazed and the Pinch roller was never cleaned. There are ways to deal with the problems but most people are too lazy so they take it to a Technician. The Pinch roller if hard needs to go to Terry for rebuild and the capstan shaft can be reconditioned. The motor needs oiling. Akai used some bad transistors in their units that make noise and have other problems and the glue they used on the PCB sometimes eats the foils away.
Oct 09, 2016 | Audio Players & Recorders
I have Akai gx 230. Its doinf Rew and FF but Play not working, though engages. Tape does not move. Can it be tape threading problem?
Could be either. If you can do some testing, check for power to the capstan motor in play configuration. If there is power at the motor terminals, the motor itself may have failed.
Aug 20, 2016 | Audio Players & Recorders
SERVO CAPSTAN MOTOR FOR REAL TO REAL AKAI GX-77
Check power drive circuit and ohm out traces on control board. The glue they used has been known to conduct and corrode through the foil traces that go to the control circuits.
Apr 17, 2014 | Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
I have an AKAI GX-4000D reel to reel machine. It plays small 3" tapes at the right speed, but when I try and play a 7" tape, the sounds are very, very fast and I can't make out what's being...
Yes, that seems to be your problem.
Regardless of the size of reel.
When the:
Capstan sleeve installed is 7 1/2 IPS
Capstan sleeve not installed is 3 3/4 IPS
Hope this helps.
Robert
Oct 06, 2008 | Audio Players & Recorders
Motor for Akai GXC-740D Casette Deck
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
Sep 07, 2008 | Audio Players & Recorders
AKAI GX-747 does not play or ff or rew. Capstan runs. Stuck in standby forward mode.
My name is Ed, I have the Akai GX-747 Reel to Reel, my problem is when press the play button it engages but the capstan does not spin up to the pinch roller. The reels do not turn.
My e-mail - edward_anderson@comcast.net
Jul 01, 2008 | Audio Players & Recorders
Akai Gx-77 reel to reel tape dech
Gx 77 is working now I have solved my prbblem with my friend. where I will get big flat belt for rewinding spool/
Nov 14, 2007 | Audio Players & Recorders
285 people viewed this question
 Grubhead
Grubhead
