Question about Bernina Bernette Deco 600
The "enlarge" icon does not appear
I would like to enlarge a pattern but the "enlarge"key does not appear after pushing "set". The only time the "enlarge/reduce"key appears is if you are working with the alphabet that is in the internal memory. Does the "enlarge/reduce" function not work when using a memory card?
Thanks, Karilynb
  • karilynd Jul 27, 2008
    There was no solution given that I could see., that's why I rated it inappropriate.
  • Anonymous Aug 17, 2008
    I believe the enlarge key only works with the Alphabet on the Deco 600.
Making metalic
Posted on Jul 26, 2008
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Sep 22, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Can one increase the size of the "preloaded" patterns on this machine?
Perhaps if you read your manual it will tell you I see no mention of a make to get a clue.
May 23, 2016 | Sewing Machines
How do I use the patterns (marked pattern selection) on front of machine. User manual does not tell how and company does not have any other information on this.
It appears that your machine basically does variations of 2 stitches: straight stitch and zig-zag, plus buttonholes. Take some time to learn your machine by downloading the Workbook (Wkbk) and working through it doing the various stitches on your machine. You will eventually figure out how to combine different selections to achieve the stitches you want. The owner's manual will show you which basic settings will make which stitches.
Instruction Manuals
SINGER 5830C Quick Sales Demo Part 1
Jan 02, 2018 | Sewing Machines
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Not stitching correctly after using pattern selectors - zigzag very messy stitch
Describe in more detail a messy stitch. It may be the cam follower that creates the patterns is not aligned and is contacting two different cams at the same time. The machine then sews both patterns at the same time. The solution may require an expert.
Apr 03, 2014 | New Home Sewing Machines
Not sewing correctly on all pattern selections and stitch length knob appears lose
sounds like the sewing machine needs to be serviced, could be a problem with a gear or cam inside the machine.
I can't move the upper stitch pattern selctor to the K position.
not sure if this is any good to you but its all i can find at mo..The machine has a 'hold' in the blank (or red) posiiton. You have to push the selector dial in a little bit then turn it. If it is in the red position it will only turn clockwise...or go to this link... can move the upper stitch pattern selctor to the position Google Search
Oct 24, 2017 | Singer Sewing Machines
How do I make a "space" in between the lettering. How do I enlarge to do stippling.
with the lettering mode, there should be a code number you program in for each letter, number and for a space as well.
Stippling is usually done by free motion stitching with a special foot so its not actually a stitch pattern, just a straight stitch that you form into the stippled pattern by moving the item as it is stitched.
Jul 20, 2011 | Elna 7200 Computerized Sewing Machine
My thread keeps breaking, and getting stuck on the nob that you change the sewing pattern
Go to www.brother-usa.com and download your manual, then enlarge the diagram for threading because somehow you are missing a step for threading. You can do this, really, just take a deep breath, change your needle and rethread your machine. I think all will be fine.
Oct 15, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
70 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
