Question about Logitech Keyboards&Mouses: MX500 Optical Mouse (MOLTMX500)
My USB mouse is not detected by Windows after I plugged in the device. what can i do? New computer with Vista will not recognize this mouse or download thereof. Is there a fix? If not, is there another Logitech mouse that can be programmed with a "double click"?
  • dougandjanis Aug 11, 2008
    USB port not the problem. It is recognized as 2nd HID-compliant mouse, having only basic functions, am not able to program optional button functions.
  • dougandjanis Aug 12, 2008
    After doing further research, I've determined that this mouse is not compatible with Windows Vista.........it can be used only as a normal functioning HID-compliant mouse, but cannot be programmed for any other of it's capabilities. Thanks for trying to help! If anyone has, or can recommend, a mouse with a "double click" optional button, please let me know.
  • 426 Answers
Check logitechs site and see if they have a vista Version of the software
Posted on Aug 11, 2008
    Sergeant:
    Champion:
  • 248 Answers
Go to my computer then control panel then select mouse then you can troubleshoot there your mouse there.
Posted on Aug 10, 2008
  • 6,487 Answers
Try to connect the mouse on another USB port and see if it will work, because sometimes this can only be a bad usb port , if you can also try to connect on another computer to check it will work..
Hope that helps..........
  • Logitech Master
  • 13,433 Answers
Hello, try another computer? does the light in the bottom come on?
  • Ekse Aug 10, 2008
    I have a mx518 here, the light in the bottom comes on when its pluged in. if it doesn't come up, you got a broken cord or a faulty mouse.
  • Ekse Aug 11, 2008
    do you have the latest version that supports your windows version?
    Sergeant:
    Champion:
  • 347 Answers
Heello dougandjanis,
first of all, make sure your USB port is working, you can try that by plugging another USB device in.
Then to check that the mouse USB is working, once you have connected it, go to:
start >(righ-click)Mycomputer>select manage>select device manager> (look in the (?) tab. see if your mouse is listed there.
Good luck, and let me know what happend,
Dahaka
Posted on Jul 23, 2008
I need a manual
James: I could not find one for you either. However, I do know that on my own computer, I can't switch a mouse without restarting my computer or it does not recognize it.
May 25, 2015 | Pixxo MA-9EG5 Black 2.4 GHz Wireless...
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
Computer does not recognize the device
Plug your Tablet in first with Computer off, Turn on Computer and see if Vista recognizes the Tablet. Go by what is suggested on the screen. It may help to do a Hard Disc DeFrag. before attempting the above.
Sep 15, 2009 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
try another usb port also try booting without it plugged in when booted plug in it may recognize it as new hardware
Jul 31, 2008 | Verbatim 95208 Mouse
Logitech Keyboards&Mouses: MX500 Optical Mouse (MOLTMX500) Logo
198 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
