Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Carpet Cleaner i was cleaning my carpet and it stopped putting out water. I changed the water tank and checked the solution everyhting was fine. what chould I do
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Aug 10, 2008
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
I was just given one of these. After cleaning an entire room and going through the entire tank of solution the recovery tank was bone dry. is that normal or should some of the water have been recovered?
Is it a carpet cleaner? If so, you should have dirty water (vacuumed from the carpet) in the recovery tank.
Most carpet cleaners have a transparent vacuum intake so you can see the dirty water going in as you pull back on the return sweep. Check for clogs or a broken belt. I advise against using you cleaner until the water pickup is repaired. Leaving water in the underlayment can cause mold,mildew and rotten floorboards.
I hope this helps. Good Luck!
Dec 15, 2014 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Why isnt my carpet cleaner releasing or putting any water out onto my carpet
I believe we own the same model or one that operates like it. If so, then yours has a "bladder" for the clean water, it has to be almost full sometimes before it will release any. Check the nozzle on the bottom of the tank body and on the cleaner for anything that might clog it up.
I think it will also release water only when you pull the cleaner toward you and hold the trigger down long enough as well...it does not release when moving forward.
Also check the bottom of the cleaner and clean off anything stuck to it...it gets pretty dirty and that is where the water comes through.
Dec 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
80 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
