Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Require compac evo 510 eathernet controller
Hard drive crased. Re-installed Microsoft XP Professional. Will not connect to modem. Message says missing driver.
Please help.
Thanks.
dd
  • Anonymous Dec 14, 2008
    Re installed windows. There is no driver for the ethernet port. cannot connect to the internet.
  • 52 Answers
Ethernet drivers for compaq evo cmt 510 for windows xp professional service pack 3
You can download the LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Mar 15, 2012 | Compaq Evo D510 Minitower (Open Box)...
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Processor: Intel Pentium D - 3.4GHz processor (Dual-Core) Memory: 2048MB RAM Hard Drive: 400GB Optical Drive: CDRW/DVD Rom drive (combo) Operating System: Microsoft Windows XP Professional SP3...
You have to have some sort of a modem to get online whether your using a smartphone through a usb or broadband modem through your rj-45 jack, Broadband modems also have the capability of using a usb cable to connect to the modem. Hope this helps. Not sure exactly what your asking. If I havent answered your question feel free to let me know!!!
Jun 13, 2011 | Dell OPTIPLEX 745 PC Desktop
Driver main compac may pc model 510cmt
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model desktop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
Jan 15, 2011 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
I am looking for multimedia audio controller driver and vga controller for compac TM serial number 6S26 GX8Z DOK6 where can I find it ?
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
Dec 08, 2010 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
Error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
Jul 14, 2009 | Compaq Evo D500 PC Desktop
HOW TO FORMAT XP /STUCK HALFWAY THRU INTALATION
Windows XP and Vista are licensed Microsoft products. We cannot give out product keys you have to purchase them from Microsoft.
May 08, 2008 | Compaq Evo D300 PC Desktop
Ethernet Drivers for Compaq Evo for XP
need an ethernet driver update and audio update
Apr 19, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
125 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
