Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Green line down left side and geen snow
Hi My tv is about 18months old. A green vertical line is running down the left hand edge of the screen and when the cable is switched off the screen is a mass of green snow. Periodically when watching tv you can see the green snow as well but it doesnt happen all the time.
Please someone tell me it isn't dying already!
  • 1 more comment
  • echo18 Jul 24, 2008
    have same intermittant problem with samsung 52 inch LCD-green snow at times with black lines...during tv programs there is moving green snow fields in the dark areas of the picture...samung tech said unplug wait a few minutes for reset and it didn't help..they changed the "mother board" and didn't help..Best Buy (where it was bought)came and did some "recalibrations" and still have this periodic problem...the tv was bought in Jan 08...Best Buy sending out tech again tomorrow...but the problem never occurs when they are here ..we just have digital photos of screen to show them
  • edgibs Jul 26, 2008
    Hi Echo18 I have just solved my problem, well sort of. My neighbour has just gone away on vacation and as we were talking about where he was going he told me he was switching all his appliances off. 10 MINUTES AFTER HE LEFT MY PICTURE RETURNED TO ABSOLUTELY PERFECT! I now have to wait 17 days til he returns to speak to him about his wireless router as I am now sure this is what has been causing my fault. I will post again on his return to let you know exactly what item of his is causing my problem, although I am sure it is going to be his wireless router. I have had 3 months of this problem and just wish he had gone aay earlier. I hope this may shed some light on your problem.
  • gav113 Nov 07, 2008
    Hi guys
    I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an indedent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
  • 335 Answers
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Posted on Jan 04, 2009
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Green line 2inch appeared on left hand edge next
look like you panel fail,
but you can get 2nd opinon
Jan 08, 2010 | Televison & Video
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Black line on TV
Try cleaning and reseating the ribbon cables on the XR board.
Mar 08, 2008 | Televison & Video
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
1,266 people viewed this question
Henry  Thomas
Henry Thomas
