Question about JVC Everio 25x/20GB Hard Disk Drive Camcorder
Connection problem Yes, my computer is having difficulty reading the connection to my JVC 30GB Hard Disk Drive. I am using Windows Movie Maker to import the video. I have tried the USB cable and the FireWire cable. Neither seem to be working. What else can I do? Thank you. Tessa Walter
  • 2794 Answers
SOURCE: JVC GR-DVP7 - Video to PC / Firewire Cable ... where can I get one?
Best Buy has a 6 pin to 4 pin firewire cable. You will need some software as well to copy to the hard drive such as Pinnacle Studio if you don't have on already.
Once the cable is plugged in and turned on Studio will detect the camera and run the program.
Posted on Jul 04, 2008
SOURCE: Cannot download video to movie maker
Has anyone got a solution for this problem yet? I'm having the same issue.
Posted on Sep 16, 2008
  • 59 Answers
You CAN NOT use the Firewire to capture your footage like DV or HDV camcorders. I too Have a macbook pro and use FCPS2 to edit my footage. If you want to get the footage off of the HD7u, you'll have to connect via USB2.0 and download the .TOD files and use a program to convert them. I use MPEGStreamclip. It will work with the .TOD files and convert them to a format that iMovie or FInal Cut will understand. If this is not for professional work you'll probably be fine converting the footage to the HDV standard or DV standard and not have to render in FCP to edit the footage.
Caution... MPEG2 codec may be needed. If you have FCP or have Quicktime pro, you probably already have it other wise you can purchase it from apple for $29.99 or if you try real hard (not to hard) you can probably find it on a torrent for free.
I hope this helps your situation
Posted on Oct 29, 2008
  • 107 Answers
SOURCE: downloading moviefiles from cam to computer so computer can read
When you bought this CAM it should come with the software install this software in your computer then you can edit whatever you want
Posted on Dec 04, 2008
SOURCE: Can't copy video files from my onto my computer
hi there,
it seems u have not installed the software onto your computer. just install the software for your camcorder with the help of a CD that u might have recieved along with the it. then plug it through USB and its ready to transfer the videos.
good luck and do not forget to rate this solution.
thanks for using FixYa
Posted on Feb 11, 2009
I'm confused. Is the maxtor drive 250GB? Have you partition it to 30GB? Or is it that the computer only reads 30GB instead of 250GB? Does this drive have Windows on it? Also you might want to check your BIOS (Motherboard input/output system) by pressing Del key or F12 and see if this drive is the startup Drive. If you don't have Windows on this drive, make sure it is NOT the startup drive. Hope this helps.
Dec 09, 2013 | Maxtor Hard Drive
Everio movie editing
First check sound settings on control panel, ensure volume is not at minimum and computer audio is not muted. Test playing a CD.
this is usually due to Media Player or whatever player you use on your pc, not having the right codecs to decompress sound from camera file.
Usually you sort it out upgrading media player, you can download update from links below.
  1. Windows Media Player 10
  2. Cumulative update for Windows Media Player 11 in Windows Vista
Sep 23, 2008 | Video Cameras
How do I transfer to DVD
If you have laptop you can try firewire connection. And even Windows Movie Maker can record it from your camera.
Aug 08, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
My computer doesn't recognize my JVC Everio camcorder
i use the video to Windows Movie maker below successfully import the footage
Check JVC to Windows Movie maker Converter
Apr 11, 2009 | Cameras
What do I need to transfer video from jvc cam to my laptop
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
You can then use Move Maker to any disc burning software like Nero to create the movie disks.
Jan 04, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
Downloading moviefiles from cam to computer so computer can read
Dec 03, 2008 | JVC Video Cameras
Using Windows Movie Maker
Windows Movie Maker is pretty picky about file formats. You might want to use Pinnacle Studio. This way once you plug your computer in and turn it on Pinnacle will capture the video for you which is something that Movie Maker was never designed to do.
Jul 04, 2008 | JVC Video Cameras
Movie Camera and Movie Maker
Hi Am Gayra, Try using the Power Producer which came with the camera
Mar 26, 2008 | JVC Everio GZ-HD7 Camcorder
Use firewire cable to coonect to a computer. Transfer the movie from camcorder to the computer (for example using Microsoft Movie Maker - included in Windows XP). Then you can edit it in Movie Maker and save the final movie on the hard disk, DVD or back on DV cassette.
Jan 19, 2008 | JVC Cybercam GR-DX75 Mini DV Digital...
Harddrive problems
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
JVC Everio 25x/20GB Hard Disk Drive Camcorder Logo
54 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
