Question about Crosley CFFH10W Top Freezer Refrigerator
Crosley refrigerator model CTH182gw-01
The freezer is working but not the defrost. I can't locate the defrost timer to see if that is the problem. Help!
5 Suggested Answers
  • 3422 Answers
SOURCE: Crosley Refrigerator Nent196H BM7A81A
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Posted on Jul 21, 2008
    SOURCE: Need replacement freezer door for model Crosley WCK05W
    The Crosley WCK05W "Compact Kitchen" is manufactured by the WC Wood Company of Canada. The Wood model number is K05W (http://www.wcwood.com/cgi-bin/ListModel.pl?loc=usa&prod=kitchen&model=K05W). Unfortunately, Wood no longer makes the unit and the replacement doors have been sold out and is no longer available.
    Posted on Mar 15, 2009
    • 363 Answers
    SOURCE: refrigerator wont stay cold.Freezer works fine,no frost buildup
    i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
    Posted on Jul 30, 2009
    • 1531 Answers
    SOURCE: Crosley model CRTE171AW1. Water drips from above
    the most commom problem is that the drain hole is covered with frozen water or the drain tube is plugged.
    Posted on Mar 10, 2010
    In there a defrost timer
    Great Majority Combo: Refrigerators Freezer Have Defrost Timers. .IF Has a FREEZER Will Have Defrost Timer ! .Many have defrost timer Below on LH or RH Walls at Bottom by Compressor Compartment..Others Have Timer on upper Partition Wall/Ceiling of refrigerator between Refrigerator & Freezer By Thermostat Long Protuding Cover.( .IF Provide Brand Model # & Serial # Of Refrigerator Most likely will get more accurate Location of Defrost Timer
    Dec 20, 2015 | Kenmore Refrigerators
    Freezer is not deforsting
    If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
    If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
    and the defrost thermostat=> WR50X122 Defrost Thermostat
    The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
    Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
    Crosley conservator is freezing, fridge not cooling
    No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
    If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
    If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
    With an ohm meter it should show continuity when cold and none when warm.
    You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
    The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
    If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
    If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
    If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
    To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
    http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
    Oct 05, 2009 | Refrigerators
    Freezer works great, but refrigeration section stopped working
    Check the door seals on fridge and freezer to make sure there are NO leaks.
    Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
    Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
    The bottom of my frigidaire is not cooling properly; and the freezer works great; is it a minor problem i can fix
    you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
    Aug 19, 2009 | Frigidaire FRT17G4B Top Freezer...
    The refrigerator side has stopped cooling.
    , you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    Aug 18, 2009 | Refrigerators
    Refrigerator and freezer not working
    you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
    Freezer not freezing
    If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Kenmore model 57029 side-by-side refrigerator not working
    If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
    Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
    Defrost timer
    generally the defrost times are located very close to compressor compartment. it can be easyly detected, by its label
    Mar 10, 2009 | Refrigerators
    Refrigerators Logo
    138 people viewed this question
    Top Crosley Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    fta777
    Colin Stickland
    Colin Stickland
    Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
