Question about GE WDSR2080D Top Load Washer
Washing machine GE washing machine top loader power button won't work. Yes the machine has power to it, I did check
  • 734 Answers
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
My ge adora top loader just wont power on at all. No lights nothing even switched wall plugs still nothing! Please help
FIRST CHECK IF THERE IS POWER ON THE OUTLET.
IF NOT CHECK THE FUSE BOX OUTSIDE YOUR HOME.
MAYBE IT POP.
Sep 18, 2016 | GE Washing Machines
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Water won't drain on the wash or rinse cycle
Hi.
If the machine does not drain the parts to be tested are rain system, motor and control board must also be tested. If machine is a top loader testing will start from lid switch. The first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your GE WSXH208A.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | GE WSXH208A Front Load Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Best washers ?
the larger capacity maytag with the larger gears in the transmission can break. the standard transmission on some of the ge are bad, the coupling breaks in the kenmore and whirlpool if you overload.
I still like maytag the best and I have been in the appliance business 19+ years
Dec 14, 2008 | GE WBSR3140DW Top Load Washer
Ge washing machine
Jul 23, 2008 | GE Profile Prodigy WPSE4200A
GE WDSR2080D Top Load Washer Logo
120 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
