Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Monitor Barely readable and dark but display is correct
The monitor powers up, and displays desktop correctly but is barely readable and very dark.
  • ldentwv Aug 07, 2008
    Thanks. I suspected as much. I will just use it on the maintenance bench. ldent
  • moyetisimo Jan 08, 2009
    I have this viewsonic VE710b monitor, it does turn on but the image is to dark, like it needed adjustment in brightness, what coulb be the problem?
  • 3 Answers
We have about 20 of these at work. Four of them went dark, to varying degrees, in the two years they were covered by warrantee, and were sent back to the factory for repairs. Since then, eleven more have gone dark. I finally got around to looking at them a few days ago. I have repaired five so far, and in every case it has been the same cause.
The capacitors on the inverter board are burning out. There are two 470uF, two 1500uF and a 1000uF that are not holding up.
Costs about 4 bucks for replacement parts at digikey; qtys and Part numbers are:
2 PN #493-1561-ND
1 PN #565-1664-ND
2 PN #P13124-ND
It takes about an hour, and minimal skill with a soldering iron to fix.
Posted on Jan 12, 2009
    New Friend:
Nice after 2 year of my second monitor is dimed I had ever think is because I was playing with the protection anti-teif but now you finally give me a reason to put back my soldering bench on work !
Tanks alot for the help!
Posted on Jan 27, 2013
  • Jean-Christophe Duperron
    Soon an image ! lol in my way to do it but can't find those capacitors!
Backlight is shot, sad but its cheaper to buy a new one
Posted on Aug 07, 2008
Dark sgreen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 25, 2012 | Dell Latitude C610 Notebook
Gateway m280 notebook black screen.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
May 24, 2012 | Gateway Computers & Internet
Gateway laptop powers up but screen does not come up.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your ideo card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 24, 2012 | Computers & Internet
Dark screen
May 23, 2012 | Computers & Internet
Power on but no display
May 15, 2012 | Computers & Internet
No Graphics
May 06, 2012 | Sony VAIO Digital Studio PCV-RS220 PC...
Hp laptop dark display
May 05, 2012 | Computers & Internet
Power on but no picture and sound
Apr 28, 2012 | Computers & Internet
My sony viao vgc-va10g has power but screen wnt turn on .
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Apr 24, 2012 | Sony Computers & Internet
Hp laptop powers up -no screen display
Mar 31, 2012 | Computers & Internet
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
353 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
