Question about Canon PowerShot A450 Digital Camera
Thankyou very much! It did indeed work for me my camera is now unlocked!!!!
Posted on Aug 30, 2008
  • 1,019 Answers
Hi Pat.
If it,s an SD Type card. there will be a small plastic-tab at the side of the card. slide it in the opposite direction, to unlock-lock.
This acts as a write protection tab, similar to floppy-Disks.
Mike @ Compurepair.
Posted on Jul 23, 2008
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Hi, my Panasonic saak-600 had the f61 problem , I change the ic stk 470-090 and the f61 dissapeared but when i turn off the system it automatically turn on after few seconde without turning on by...
seems the system is fine and what you see is display demo of the system.
while the system is on standby or even if it is on keep pressing the display button
until "no display" is displayed on the screen.
Nov 17, 2010 | Panasonic SC-AK600 CD Shelf System
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Oct 13, 2010 | Protron PLTV-32 Television
IP address
If you lose the IP address you can reset the network card.
Since the machine no longer has an IP address, you MUST be connected with a network cable.
1. Turn the power off
2. Press and hold the "go" button (the blue one on the front)
3. While holding the Go button, turn the power back on.
4. Keep holding the Go button until all 4 lights are on.
5. Release the "Go" button and press it 7 times quickly.
This will reset the network card and you should get a proper wired LAN IP address.
Mar 31, 2010 | Brother HL-2170W Laser Printer
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
Pull the card out of the camera and slide the tiny slide switch on the card to the other position. All the SD-type cards that I have met have this lock on them.
Jun 27, 2009 | Samsung BL103 Digital Camera
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Outside temperature gauge malfunction
Hi pat the temp sensor is on the left side below the grill a black pointed sensor just cliped behind the splitter bar i would just change it. the temp wont change right away drive the car a couple of miles D
Jan 05, 2009 | 2005 Jaguar X-Type
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
If you accidentally lock the projector, you need to disconnect the AC power cord. Then HOLD the SELECT button at the same time as reconnecting the AC power cord again.
This should reset the lock out.
Dec 24, 2007 | Sanyo PLC-XU47 Multimedia Projector
Canon PowerShot A450 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
