Question about Acer Aspire 5100 Notebook
Still, No luck with laptop
I tried switching the memory sticks around and only using one. My laptop is still unresponsive. Do you have any more suggestions?
-unresponsive laptop
  • Anonymous Feb 07, 2009
    My acer computers starts up then restarts in safe mode what should i do
    Guru:
  • 859 Answers
Your laptop is booting to a Windows Desktop, so there is no hardware fault or Ram isssue. You may have a lack of free space on C:, but I would suggest the following:
Shut off your laptop if its not off already. Restart after a moment and press F8 while booting, this should get you a startup menu for using Safe Mode. Select Safe Mode and then your presented with an OS choice, usually your windows installation is already highlighted. If it is hit enter, if it isn't use the up/down arrow keys to highlight it and tehn hit enter.
Once you reach a desktop environment you are warned that you are entering Safe Mode, acknowledge that notification, you will proceed into Safe Mode dektop. Does your mouse do what you want? When you press the Windows Logo key on your keyboard does the start menu pop up?
If so, let us know with a reply using the comment box below. We can take some measures to get your problem taken care of shortly.
Regards,
Worldvet
Posted on Jul 31, 2008
Toshiba satellite l505D-s5983 Keeps freezing and going unresponsive
This sounds like ram memory issue, remove one stick of ram and power up, no change, remove second piece and replace the first, if this works the memory stick in your hand is defective.
Jun 16, 2012 | Toshiba Satellite L505DS5983 Notebook
7 beep error message for dell inspiron mini 1018
For the Dell Inspiron Mini 1012 Netbook, 7 beeps indicates bad memory (system RAM). The memory will need to be replaced.
The RAM can be replaced using a small Phillips screwdriver and removing the back-plate on the bottom of the laptop. When you see the memory (sticks around 3 inches long), pull those out and put new ones in. Make sure it's the correct DDR2 memory.
May 06, 2011 | Dell Inspiron Mini 1012 Netbook...
I can't locate were you install the memory modules
You can purchase 1GB ram sticks for them...need to shop around.
Access the ram slots by switching laptop off / remove battery / depress on / off switch several X to de-enrgise system. Turn laptop upside down and remove one of the small panels...be carefull you do not lose screws. Very carefully unclip ram stick / lift up and out.
Mar 12, 2010 | Toshiba Satellite A20-S207 Notebook
Asus p4s800 beep codes. I get one long beep. I
The one long beep, this has something to do with the video card.
Can't really tell without the BIOS you are using !
Anyway, try removing the card and replace it. ( with anything, just to check. )
This is a good board, I have a ASUS P4C800 and you can't beet it.
P.S. Make sure all your memory is the same freq. and clock speed.
Good luck.
Oct 23, 2009 | ASUS P4S800-MX Motherboard
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
No post no video Beeps once every sec. The first few times it boot I had video. Then lost video now I have it back. it will run all day when in the bios. But outside the bios trying to load Windows XP home...
Hi...
Actually the problem is the memory witch is beeping every seconds during turning the laptop on. Check your memory stick, remove the memory stick, clean from dust. Reinsert it try to use the other memory slot. If the problem is still occurs the memory stick is bad or faulty already. You need to replace the memory stick.
Thanks for using fixya
Regards
PCmania
Aug 15, 2009 | Toshiba Computers & Internet
Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Sharp pc al27
swap the memory sticks around,this usually works for me.
good luck
Terry
Mar 19, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
